Koni Reds - Bump Stop Question |
Craigers17 |
Aug 16 2023, 04:43 AM
Senior Member Group: Members Posts: 744 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
I recently picked up some slightly used rear Koni Reds with coilovers and 180lb springs on Ebay. It was a great deal and I couldn't pass it up. My question is what bump stop to use at the top? Should I use the stock one or go with one of Koni's Yellow foam type of bump stop? Any suggestions would be appreciated, especially from those who have Konis.
I have included a pic below of the setup: |
stownsen914 |
Aug 16 2023, 06:23 AM
Senior Member Group: Members Posts: 915 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I'd test fit one to the car and see how much "bump" travel you'll have with your setup with bump stops in place (ride height, wheel & tire combo, etc.) You'll want 2-3" so you don't hit the bump stops during normal use. Hitting bump stops can cause erratic handling, especially if they are engaged during a turn, because the effective spring rate basically goes to infinity when the shocks bottom onto them. If that will be the case, definitely get the Koni ones - they are softer and progressive, so much less intrusive when they are engaged.
Lo-Fi Version | Time is now: 7th June 2024 - 09:24 PM |
