rfinegan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,083 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region ![]() ![]() |
Here is a link to part one:
http://www.914world.com/bbs2/index.php?sho...117&hl=2056 I decide my t1 oil pump in my 2056 was doing me no favors with a smaller than ideal OD. I still had the T4 oil pump from the 2.0 that was doing its job when I had a cam thrust bearing fail /knock, so I decided to pull it a part for inspection. I will perform some measurements and get it cleaned up, if it turns out to be in good shape. The pics look like a great core. ![]() |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
On a first run in like you just did I clean the piss out of my drain pan, drain oil into it.
Let it sit for hours, poor the top 95% off and "pan for gold" with the remains. Shine a flashlight through it.... Any bad glitter and I'm pulling it back out... It's so much cheaper to fix if you catch badness early. I wouldn't do an oil analysis until after I had 10K on the new motor. |
Lo-Fi Version | Time is now: 13th July 2025 - 04:45 PM |
