> Headlight mystery, Wining headlights
robkammer
post Aug 20 2023, 05:15 AM
Teeners: As I was replacing my headlights, I found that the right side would not go down to be flush as it had before I replaced the lamp. I've been staring at it for hours, running it up and down and am stumped as to where I may be able to adjust the bucket. The pushrod bushings are not perfect, but OK. I'm thinking that the shop that installed them for the PO might have rigged the covers in some manner and I didn't notice it when I pulled the surrounds off.
The bigger mystery is that now, the left light turns on and goes DOWN when the right light goes UP.Turn the lights off and the right goes Down and the left goes UP. The only wires I touched were the plugs to the lamp. I disconnected the battery and cycled the left side to match the right. Under power the same thing happened, right side up and on, and the left side up and down. Swapped relays and no change.
I'm stumped and hope that someone else has seen this and can share with me what I messed up.
I have a deadline too, Teenerfest in TN is coming up quickly.
Rob
Tonyooc
post Aug 20 2023, 05:20 AM
I had a similar issue where they would both go up but only one would go down. I found a bad ground wire up near the headlights. I had done the relay swap as well.
- Lo-Fi Version Time is now: 1st August 2025 - 03:44 AM
