| DennisV |
Aug 19 2023, 03:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 951 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
I am having trouble locating replacements for a few of our oil system components. Missing when I got the car. 1970 914-6. Highlighted in yellow and descriptions below. Mostly hardware, and a couple rubber pieces discussed in another thread.
Does anyone have a source new or used? I have searched the usual suspects with regards to Porsche and 914-centric parts vendors. A couple I even ordered from, but then they were unable to deliver. In lieu of a supplier, perhaps someone has access to these parts that could offer dimensions for the support and tube clamps? ![]()
| rgalla9146 |
Aug 20 2023, 08:51 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,966 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
# 78 rubber washer between inner fender and tank
# 18-2 grommit, hose through shelf # 18-3 Norma hose clamp 18mm supports tube below front engine tin # 18-4 small 90 degree bracket attached to front engine tin to support oil tube # 18-7 not sure but may be Norma 18mm clamp to support tube below chain housing # 19-2 grommit on hook on body # 19-3 30mm Norma clamp that attaches to heat exchanger to protect hose from hot exhaust Attached thumbnail(s) |
| DennisV |
Aug 20 2023, 09:44 AM
# 78 rubber washer between inner fender and tank # 18-2 grommit, hose through shelf # 18-3 Norma hose clamp 18mm supports tube below front engine tin # 18-4 small 90 degree bracket attached to front engine tin to support oil tube # 18-7 not sure but may be Norma 18mm clamp to support tube below chain housing # 19-2 grommit on hook on body # 19-3 30mm Norma clamp that attaches to heat exchanger to protect hose from hot exhaust Thank you for taking time to share this. The photos help a lot with context and positioning. The Norma markings on the clamps will help me track those down. I assume the number matches the OD in mm of the pipe it is clamping. Thanks again! (IMG:style_emoticons/default/beer.gif) |
DennisV Oil System Parts Suppliers Aug 19 2023, 03:30 PM
914Sixer Clamps and grommets are available a some local aut... Aug 19 2023, 04:52 PM
johnhora :agree: the adel type clamps are universally avai... Aug 19 2023, 07:20 PM
DennisV
the adel type clamps are universally available
F... Aug 19 2023, 08:03 PM
rgalla9146 Dennis
The 'blow-up' illustration con... Aug 19 2023, 07:31 PM
rgalla9146 Oil plumbing supports Aug 20 2023, 08:54 AM
rgalla9146 attachment point on engine tin Aug 20 2023, 08:57 AM
DennisV I looked all over for correct sized Norma clamps f... Nov 30 2023, 02:12 PM
930cabman Yes, there are several of us working on a /6 conve... Nov 30 2023, 04:30 PM
slammin did you try stoddards for your pts slammin Nov 30 2023, 10:29 PM
DennisV I came across a couple even closer matching parts,... Dec 14 2024, 01:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th May 2026 - 01:22 PM |
