technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
I'm currently restoring the rear suspension on my 75 1.8l and wanted to get other's suggestions regarding rear bushings.
My shafts are fine and I'm planning on re-using them. I already have a set of bushings. Mine are the "Daystar" polygraphite set that you can get from multiple vendors. These are in AutoAtlanta packaging. These puppies fit stupid loose in the arms... I worry about squeaking... I don't like straight poly bushings for the most part. Would you use them? What grease would you use on them? Normal silicon grease for urethane bushings? 914Rubber has a rubber set that are reasonable. $ 44 PMB and Elephant racing have rubber sets that are far more costly. $92, $240 This car will be a mildly upgraded streetcar for enjoyment not competition. I'm leaning toward the 914Rubber set... What says the hive mind? |
DennisV |
Senior Member ![]() ![]() ![]() Group: Members Posts: 670 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California ![]() ![]() |
I'm currently restoring the rear suspension on my 75 1.8l and wanted to get other's suggestions regarding rear bushings. My shafts are fine and I'm planning on re-using them. What grease would you use on them? I'm just a little ahead of you. Have you already removed the old pivot shafts? Ours looked good until I got them out of the bushing. If searching for shafts, everyone I spoke to was carrying sold shafts except Restoration Design. While I'm sure the solid shafts are just fine, it seemed like unnecessary weight to me. ![]() If shooting for originality or street ride, you might want to go rubber for the bushing. The other compounds are reported to give a pretty harsh ride according to the vendors I spoke with. Based on what I can gather, Precom is original 85 durometer and supplies Restoration Design, Porsche, Rebel Racing and Elephant Racing. I believe 914Rubber is the same spec, but perhaps from a different manufacturer. For installation, I haven't seen anyone using grease. I've seem some dish soap used. |
Lo-Fi Version | Time is now: 11th July 2025 - 05:29 AM |
