| brant |
Aug 22 2023, 07:28 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,179 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Spent the weekend going over ver the car
Started packing last night Time for a road trip Attached thumbnail(s) |
| majkos1 |
Aug 28 2023, 08:04 AM
Member ![]() ![]() Group: Members Posts: 265 Joined: 11-August 17 From: Mile High 914 Member No.: 21,338 Region Association: Rocky Mountains |
Just drain oil to adjust valve to eliminate backfire issues ,
Dual carbs,40's, fresh built (tight compression) more difficult to turn motor to check the valves ,Ugh "Real 914 mechanic don't do Yoga" further hampered by fuel lines right above timing mark, previous mechanic (IMG:style_emoticons/default/smash.gif) Big push to get some mileage on this BB 914 before Red rock work out bugs, Having issues with oil temo gauge pegged. Tach not working,(MSD ignition) (sourcing out a convertor for this ) Good news A/R works like a charm, tad lean now. Goal today, put together interior enough to test drive. Quick run down on BB, Most of the gang here in Mile High city knows I had this BB 914 in and out of my garage for years. I finally get running but only on three cylinders, Two rebuild later, first failed, aftermarket Fuel injection ruin motor Second rebuild, running on Progressive carb, just to break in motor, One cylinder major leak between head and cyn. BB went to a VW expert (I got married, BIG Mistake!!)where he found leak. Engine fixed and tons of unnecessary work by previous mech, He started having health issue (Brain damage) BB was ready for pavement when develop Huge oil leak. BB got shelved. I volunteered to take a look, (am Free from Nasty marriage) Fixed leak, corrected Non 914 stuff. Took on task of Dual carbs, (am Not a big fan of ) motor build for it and am willing to learn . this where I am at. This Girl gonna rip! |
brant Is anyone else wrenching in preparation for RRC? Aug 22 2023, 07:28 AM
NARP74 Yes on the wrenching, working on a long list of th... Aug 22 2023, 08:08 AM
Front yard mechanic Is my tee shirt in that trunk? Aug 22 2023, 01:57 PM
brant
It’s not
I th... Aug 22 2023, 03:17 PM
Front yard mechanic
It’s not
I t... Aug 22 2023, 07:03 PM
StratPlayer Yes working on odds and ends to make sure the car ... Aug 22 2023, 07:01 PM
NARP74 Finding some really strange stuff.
A loose axle ... Aug 27 2023, 04:58 PM
technicalninja My hats off to you guys! :first:
Those who d... Aug 27 2023, 05:32 PM
worn Several points to address. Oil change. I also ha... Aug 27 2023, 08:20 PM
sb914
If you’re going up 101 I have a guest room wait... Aug 28 2023, 03:21 PM
worn
[quote name='worn' post='3098433' date='Aug 27 20... Aug 28 2023, 05:48 PM
JamesM I usually just wait until the night before to see ... Aug 28 2023, 08:21 AM
Front yard mechanic
I usually just wait until the night before to see... Aug 28 2023, 03:06 PM
worn Today I discovered that the crankshaft pulley had ... Aug 28 2023, 05:50 PM
brant
Today I discovered that the crankshaft pulley had... Aug 29 2023, 11:25 AM
worn
Today I discovered that the crankshaft pulley ha... Aug 29 2023, 04:49 PM
worn RE: Is anyone else wrenching in preparation for RRC? Aug 29 2023, 04:57 PM
NARP74 Weather looks like mid 70's during the day, an... Aug 28 2023, 08:22 AM
majkos1
Weather looks like mid 70's during the day, a... Aug 28 2023, 09:37 AM
NARP74
Weather looks like mid 70's during the day, ... Aug 28 2023, 09:53 AM
majkos1
[quote name='majkos1' post='3098537' date='Aug 28... Aug 28 2023, 01:06 PM
ThinAir Yes to wrenching, at least on Mike's car. Engi... Aug 29 2023, 11:02 AM
NARP74 Cool stuff Worn Aug 30 2023, 08:04 AM
NARP74 Fixed my fuel sender last night so I can see how m... Aug 30 2023, 08:06 AM
worn
Fixed my fuel sender last night so I can see how ... Aug 30 2023, 07:21 PM
worn Got the engine tin sorted and installed. Should r... Aug 30 2023, 07:26 PM
NARP74
Got the engine tin sorted and installed. Should ... Aug 30 2023, 07:54 PM
rhodyguy Amazing how quickly molten aluminum can go thru bo... Aug 31 2023, 02:41 PM
worn
Amazing how quickly molten aluminum can go thru b... Aug 31 2023, 07:12 PM
worn A week to go. Was going to fix a couple of door d... Sep 4 2023, 03:46 PM
NARP74 That's always the way with old cars.
Swapping... Sep 4 2023, 04:08 PM
worn
Swappin... Sep 4 2023, 05:33 PM
Front yard mechanic Thought about the cold dip and tried this Sep 4 2023, 06:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 04:34 AM |
