> removing fan belt, need help
Name is Snick
post Aug 28 2023, 05:17 PM
This is on a 912E but I guess it’s the same on a 914.
Do I have to remove the Alternator pulley to get the fan belt off?
The adjustment doesn’t seem to adjust far enough to get the belt off.
Thanks
bkrantz
post Aug 28 2023, 07:22 PM
Worst case, you can unscrew the adjustor bolt completely (and catch the T-profile nut). That might let you rotate the alternator just a bit more.
Name is Snick   removing fan belt   Aug 28 2023, 05:17 PM
Porschef   :wttc: Nope, should travel low enough on the adj...   Aug 28 2023, 05:19 PM
Van B   Negative, just make sure the adjuster is loose, ge...   Aug 28 2023, 05:20 PM
brant   There is a bottom bolt that the alternator pivots ...   Aug 28 2023, 05:25 PM
Name is Snick   There is a bottom bolt that the alternator pivots...   Aug 28 2023, 06:54 PM
r_towle   Sometimes a fat flathead screw driver on the alter...   Aug 28 2023, 06:58 PM
Name is Snick   Sometimes a fat flathead screw driver on the alte...   Sep 20 2023, 11:07 AM
930cabman   Sometimes a fat flathead screw driver on the alt...   Sep 20 2023, 11:26 AM
Name is Snick   [quote name='Name is Snick' post='3102967' date='...   Sep 20 2023, 11:44 AM
bkrantz   Worst case, you can unscrew the adjustor bolt comp...   Aug 28 2023, 07:22 PM
r_towle   Worst case, you can unscrew the adjustor bolt com...   Aug 28 2023, 07:46 PM
emerygt350   Jack up one side, put it in 5th, roll a tire. Sin...   Sep 20 2023, 11:19 AM
Name is Snick   Jack up one side, put it in 5th, roll a tire. Si...   Sep 20 2023, 11:52 AM
porschetub   Jack up one side, put it in 5th, roll a tire. S...   Sep 20 2023, 01:53 PM
Name is Snick   Jack up one side, put it in 5th, roll a tire. Si...   Sep 22 2023, 06:54 AM
Shivers   Jack up one side, put it in 5th, roll a tire. S...   Sep 22 2023, 07:17 AM
Name is Snick   [quote name='Name is Snick' post='3103281' date='...   Sep 22 2023, 11:21 AM
930cabman   [quote name='Name is Snick' post='3103281' date=...   Sep 22 2023, 12:29 PM
Name is Snick   [quote name='Name is Snick' post='3103328' date='...   Sep 25 2023, 08:29 AM
930cabman   I recently had a "locally rebuilt" alter...   Sep 20 2023, 03:51 PM
Front yard mechanic   Just drive it 90 mph trying to keep up @red rocks ...   Sep 20 2023, 05:14 PM
ClayPerrine   The belt is too short. A pocket knife will get it...   Sep 22 2023, 04:42 AM
- Lo-Fi Version Time is now: 10th July 2025 - 08:39 AM
