> Fuel Pressure?, Pump and Regulator
stoneman30hotmail
post Aug 29 2023, 06:03 PM
I have a 1.7L. The pump I have looks like this. Attached Image https://www.lceperformance.com/ProductDetai...eUaAvWtEALw_wcB
Where I see it says it is 5psi and recommends a pressure regulator. But I don't see one.
I have this single carb. Attached Image
How bad is that? Do I really need a regulator? What is going on without it?
Related is that the PO said they recently gave up on FI. But I assume no engine work was done.
I found this pump in the trunk. Attached Image
Recommendations?
ndfrigi
post Aug 29 2023, 08:47 PM
1. The lower fuel pump you saw was the original FI fuel pump with around 30 psi.
2. Looks like previous owner replaced the fuel pump to low psi. If it indicated 5psi. You need pressure regulator that can lower it to 2 psi.
3. Single carb usually need only between 2 to 3 psi.
- Lo-Fi Version Time is now: 14th April 2026 - 06:15 AM
