> What's causing this mess?, 1973 2.0 with 90,000 miles.
DdHavtech
post Aug 29 2023, 09:05 AM
I think I know the answer - but seems a bit excessive.
The shifter cover was just removed and cleaned. Doesn't seem like the shift seal is the problem.
Thanks
Superhawk996
post Aug 30 2023, 08:27 AM
All suggestions above are good - especially the smell test. Need to know if it’s gear oil or engine oil.
There is a lot of oil residue up high on the tail end of the trans. That usually isn’t from engine oil.
I’ve seen this occur when the transmission vent is blocked. Internal pressure inside the trans pushes gear oil out everywhere - input shaft seals, differential carrier seals, speedo gear, gear shift seal, etc., anywhere it can relieve pressure.
Can also occur when the trans is overfilled. Sort of hard to overfill if done properly but I’ve seen them overfilled when filled on the bench or garage floor.
DdHavtech   What's causing this mess?   Aug 29 2023, 09:05 AM
GregAmy   Is it transaxle or engine oil? Is it only the rig...   Aug 29 2023, 09:14 AM
Root_Werks   You can smell gear oil vs engine oil. See if you ...   Aug 29 2023, 09:16 AM
brant   could be a main seal in the engine... could be the...   Aug 29 2023, 09:54 AM
emerygt350   Looks like the gasket in the cv might be gone. Co...   Aug 29 2023, 10:01 AM
rhodyguy   RMS. No way a cv contains that much lube. What eve...   Aug 29 2023, 10:09 AM
porschetub   RMS. No way a cv contains that much lube. What ev...   Aug 29 2023, 02:25 PM
porschetub   RMS. No way a cv contains that much lube. What ev...   Aug 29 2023, 02:26 PM
JeffBowlsby   Take it to a coin op car wash and then immiedately...   Aug 29 2023, 10:18 AM
technicalninja   Take it to a coin op car wash and then immiedatel...   Aug 29 2023, 10:47 AM
930cabman   :wttc: How long has this been acting up? just si...   Aug 29 2023, 12:18 PM
emerygt350   It looks pretty old...   Aug 29 2023, 01:48 PM
Aerostatwv   Mine looked similar. Dropped the motor and transax...   Aug 29 2023, 03:01 PM
930cabman   Mine looked similar. Dropped the motor and transa...   Aug 30 2023, 04:59 AM
Shivers   Giving it the taste test will tell you a lot. :D ...   Aug 29 2023, 03:09 PM
r_towle   Trans axle shaft seals (o-ring) and cv joint gaske...   Aug 29 2023, 05:40 PM
bobboinski   Speedometer drive is at least part of it.   Aug 29 2023, 06:38 PM
Front yard mechanic   Oop   Aug 30 2023, 05:36 AM
technicalninja   Coin operated car wash?wtf is that Decades ago ...   Aug 30 2023, 07:13 AM
wonkipop   Coin operated car wash?wtf is that Decades ago...   Aug 30 2023, 07:55 AM
JeffBowlsby   Coin operated car wash?wtf is that Where I...   Aug 30 2023, 09:24 AM
Superhawk996   Answer to the thread’s title question: lack of...   Aug 30 2023, 08:14 AM
76-914   That Cv gasket is gone. Usually they will leave a ...   Aug 30 2023, 08:25 AM
Superhawk996   All suggestions above are good - especially the sm...   Aug 30 2023, 08:27 AM
jhynesrockmtn   My 70 looked like that and really spewed fluid out...   Aug 30 2023, 08:33 AM
technicalninja   [quote name='technicalninja' post='3098957' date=...   Aug 30 2023, 09:45 AM
rhodyguy   OP, do you have to add engine oil on a regular bas...   Aug 30 2023, 02:18 PM
Rusty   That's pretty grungy. Dr Evil used to recom...   Aug 30 2023, 07:17 PM
GregAmy   I'm still waiting for the OP to let us know if...   Aug 30 2023, 08:38 PM
930cabman   I'm still waiting for the OP to let us know i...   Aug 31 2023, 05:00 AM
- Lo-Fi Version Time is now: 30th April 2026 - 12:12 PM
