| stoneman30hotmail |
Aug 29 2023, 06:03 PM
Member ![]() ![]() Group: Members Posts: 80 Joined: 10-September 22 From: Greensboro, NC Member No.: 26,834 Region Association: South East States |
I have a 1.7L. The pump I have looks like this.
Where I see it says it is 5psi and recommends a pressure regulator. But I don't see one. I have this single carb. How bad is that? Do I really need a regulator? What is going on without it? Related is that the PO said they recently gave up on FI. But I assume no engine work was done. I found this pump in the trunk. Recommendations? |
| brant |
Aug 30 2023, 10:56 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,179 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
your question about whether you need the regulator:
the needle and seat in the carb stops the fuel from flowing in. they can stop and handle pressure around 3psi... sometime 4psi but much higher and they will blow the needle open and continue to add fuel to the carb even if the bowl is full already. So the bowl can overflow and start a fire if the leaking gasoline hits the headers or another source of ignition. |
| stoneman30hotmail |
Aug 30 2023, 03:13 PM
your question about whether you need the regulator: the needle and seat in the carb stops the fuel from flowing in. they can stop and handle pressure around 3psi... sometime 4psi but much higher and they will blow the needle open and continue to add fuel to the carb even if the bowl is full already. So the bowl can overflow and start a fire if the leaking gasoline hits the headers or another source of ignition. Good to know. We did smell gas pretty stong after the 3 mile drive home a year ago. It's probably this and/or the open carbon canister lines. Not sure how much the PO drove it since the changeover. |
stoneman30hotmail Fuel Pressure? Aug 29 2023, 06:03 PM
ndfrigi 1. The lower fuel pump you saw was the original F... Aug 29 2023, 08:47 PM
porschetub
your question about whether you need the regulat... Aug 31 2023, 02:26 PM
rjames Did the PO give you the FI stuff, too? If so, cons... Aug 30 2023, 12:55 PM
stoneman30hotmail
Did the PO give you the FI stuff, too? If so, con... Aug 30 2023, 03:07 PM
VaccaRabite Its probably an internally regulated pump thats pu... Aug 30 2023, 02:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 06:15 AM |
