technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
I'm currently restoring the rear suspension on my 75 1.8l and wanted to get other's suggestions regarding rear bushings.
My shafts are fine and I'm planning on re-using them. I already have a set of bushings. Mine are the "Daystar" polygraphite set that you can get from multiple vendors. These are in AutoAtlanta packaging. These puppies fit stupid loose in the arms... I worry about squeaking... I don't like straight poly bushings for the most part. Would you use them? What grease would you use on them? Normal silicon grease for urethane bushings? 914Rubber has a rubber set that are reasonable. $ 44 PMB and Elephant racing have rubber sets that are far more costly. $92, $240 This car will be a mildly upgraded streetcar for enjoyment not competition. I'm leaning toward the 914Rubber set... What says the hive mind? |
technicalninja |
Thanks for all the replies.
I've decided to try Mikey's rubber bushings. I got a bunch of other stuff to order from them anyway. On my other car, a 76 916 clone, I'll used either the Elephant poly bronze or maybe the RSR ones. I wasn't aware of those, and I like the perfect reproduction shafts better. Thanks for the heads up yeahmag. That decision will happen far down the road... |
Lo-Fi Version | Time is now: 11th July 2025 - 03:19 AM |
