> Don't know what happened, Any suggestions?
Carlitos Way
post Jan 24 2005, 01:40 PM
I did it MY WAY
VROOM... VROOOM, turn the corner, sputter, sputter, backfire, backfire, lose power, engine starts dying, floor the gas, downshift, sputter, sputter, backfire, backfire, back to normal for 2 blocks... then sputter, sputter, and turned it off when I got home.
Anyone venture a guess?
SLITS
post Jan 24 2005, 02:51 PM
"This Utah shit is HARSH!"
Which way did you turn? If it was left, the german windsucker is protesting against NASCAR manuvers.
To cure it you must turn right four times and not spit tabacco.
Carlitos Way   Don't know what happened   Jan 24 2005, 01:40 PM
iiibdsiil   Water in the gas maybe?   Jan 24 2005, 01:56 PM
scott thacher   check your fuel pressure mine did that when my ret...   Jan 24 2005, 01:59 PM
!   All the abocve and/or clogged fuel filter. Have y...   Jan 24 2005, 02:00 PM
bondo   points maybe?   Jan 24 2005, 02:01 PM
Carlitos Way   Well, so far I haven't run it down to fumes th...   Jan 24 2005, 02:13 PM
SirAndy   <...   Jan 24 2005, 02:21 PM
vsg914   I agree with the clogged fuel filter theory. Mine ...   Jan 24 2005, 02:23 PM
Elliot Cannon   "It aint got no gase in it!" (Billy Bob T...   Jan 24 2005, 02:24 PM
SLITS   Which way did you turn? If it was left, the germa...   Jan 24 2005, 02:51 PM
ArtechnikA   AAR wire loose and/or otherwise shorting to sheet ...   Jan 24 2005, 03:31 PM
roundboy914   yeah, i was going to say coil wire, that thin litt...   Jan 24 2005, 05:10 PM
jwalters   http://www.914world.com/bbs2/html/e...   Jan 24 2005, 07:48 PM
Mike D.   Try sticking one of those retractable magnet thing...   Jan 25 2005, 12:58 AM
DJsRepS   Pull clean and lube put back and then ohm your tri...   Jan 25 2005, 06:11 AM
JB 914
- Lo-Fi Version Time is now: 8th July 2025 - 05:37 PM
