Carlitos Way
Jan 24 2005, 01:40 PM
VROOM... VROOOM, turn the corner, sputter, sputter, backfire, backfire, lose power, engine starts dying, floor the gas, downshift, sputter, sputter, backfire, backfire, back to normal for 2 blocks... then sputter, sputter, and turned it off when I got home.
Anyone venture a guess?
iiibdsiil
Jan 24 2005, 01:56 PM
Water in the gas maybe?
scotty914
Jan 24 2005, 01:59 PM
check your fuel pressure mine did that when my return line got clogged, if i reved it the fuel pressure would drop for a few then climd again
Joe Bob
Jan 24 2005, 02:00 PM
All the abocve and/or clogged fuel filter. Have you run it down to fumes lately?
bondo
Jan 24 2005, 02:01 PM
points maybe?
Carlitos Way
Jan 24 2005, 02:13 PM
Well, so far I haven't run it down to fumes that I can remember, but with a non-operable/inaccurate gas gauge... that's a possibility... I guess I could also try points and condenser... haven't replaced those since I got the car... that was 3 months ago...
Any sources recommended for purchasing these? upgrades (other tan pertronix) recommended?
Jan 24 2005, 02:21 PM
QUOTE (cmolina @ Jan 24 2005, 11:40 AM) |
Anyone venture a guess? |
CHT came lose. or the wire to it broke ...
TheCabinetmaker
Jan 24 2005, 02:23 PM
I agree with the clogged fuel filter theory. Mine did the same thing. Stumbled and sputtered on every left hand corner. All is well now.
Elliot_Cannon
Jan 24 2005, 02:24 PM
"It aint got no gase in it!" (Billy Bob Thornton Sling Blade)
Elliot
SLITS
Jan 24 2005, 02:51 PM
Which way did you turn? If it was left, the german windsucker is protesting against NASCAR manuvers.
To cure it you must turn right four times and not spit tabacco.
ArtechnikA
Jan 24 2005, 03:31 PM
AAR wire loose and/or otherwise shorting to sheet metal and taking out the fuel pump -- not enough to actually blose the fuse, just enough to make it run bad.
or - more likely - loose wire at the coil.
roundboy914
Jan 24 2005, 05:10 PM
yeah, i was going to say coil wire, that thin little pos loves to crack, come loose.
jwalters
Jan 24 2005, 07:48 PM
I bet it is a chop stick clogging your flux capacitor which is throwing the fuel conditioning unit into a graveyard spiral..........but I could be wrong......
J/K--sounds like something really cheap and small----
Mike D.
Jan 25 2005, 12:58 AM
Try sticking one of those retractable magnet things down in the gas tank and hope nothing comes out. However, loss of fuel should't cause backfire, check wire harness at all the sensors, dist., and coil.. probably something just loose..
-Mike D.
DJsRepS
Jan 25 2005, 06:11 AM
Pull clean and lube put back and then ohm your trigger points as process of elemination. Also check all your FI harness grounds. Assumeing your running FI that is. Check your fuel pressure as well. A clogged retrun line as mentioned above could double the pressure thus flooding motor and make for black smoke out the tailpipe.
JB 914
Jan 26 2005, 02:04 AM
QUOTE (Elliot Cannon @ Jan 24 2005, 12:24 PM) |
"It aint got no gase in it!" (Billy Bob Thornton Sling Blade) Elliot |
i can do that voice
