Carlitos Way |
I did it MY WAY ![]() ![]() ![]() Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California ![]() |
VROOM... VROOOM, turn the corner, sputter, sputter, backfire, backfire, lose power, engine starts dying, floor the gas, downshift, sputter, sputter, backfire, backfire, back to normal for 2 blocks... then sputter, sputter, and turned it off when I got home.
Anyone venture a guess? |
iiibdsiil |
Needs Door Locks ![]() ![]() ![]() Group: Members Posts: 605 Joined: 19-November 03 From: Tampa / Boca Raton, FL Member No.: 1,362 ![]() |
Water in the gas maybe?
scotty914 |
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,528 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 ![]() |
check your fuel pressure mine did that when my return line got clogged, if i reved it the fuel pressure would drop for a few then climd again
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
All the abocve and/or clogged fuel filter. Have you run it down to fumes lately?
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
points maybe?
Carlitos Way |
Well, so far I haven't run it down to fumes that I can remember, but with a non-operable/inaccurate gas gauge... that's a possibility... I guess I could also try points and condenser... haven't replaced those since I got the car... that was 3 months ago...
Any sources recommended for purchasing these? upgrades (other tan pertronix) recommended? |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,245 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
CHT came lose. or the wire to it broke ... |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I agree with the clogged fuel filter theory. Mine did the same thing. Stumbled and sputtered on every left hand corner. All is well now.
Elliot_Cannon |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None ![]() |
"It aint got no gase in it!" (Billy Bob Thornton Sling Blade)
Elliot |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Which way did you turn? If it was left, the german windsucker is protesting against NASCAR manuvers.
To cure it you must turn right four times and not spit tabacco. |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
AAR wire loose and/or otherwise shorting to sheet metal and taking out the fuel pump -- not enough to actually blose the fuse, just enough to make it run bad.
or - more likely - loose wire at the coil. |
roundboy914 |
Member ![]() ![]() Group: Members Posts: 210 Joined: 16-October 03 From: Chicago, IL Member No.: 1,251 ![]() |
yeah, i was going to say coil wire, that thin little pos loves to crack, come loose.
jwalters |
Sooo Close....... ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) I bet it is a chop stick clogging your flux capacitor which is throwing the fuel conditioning unit into a graveyard spiral..........but I could be wrong...... (IMG:http://www.914world.com/bbs2/html/emoticons/bravo.gif)
J/K--sounds like something really cheap and small---- |
Mike D. |
OK, It runs now, and pretty good too! ![]() ![]() ![]() Group: Members Posts: 1,455 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None ![]() ![]() |
Try sticking one of those retractable magnet things down in the gas tank and hope nothing comes out. However, loss of fuel should't cause backfire, check wire harness at all the sensors, dist., and coil.. probably something just loose..
-Mike D. |
DJsRepS |
Member ![]() ![]() Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 ![]() |
Pull clean and lube put back and then ohm your trigger points as process of elemination. Also check all your FI harness grounds. Assumeing your running FI that is. Check your fuel pressure as well. A clogged retrun line as mentioned above could double the pressure thus flooding motor and make for black smoke out the tailpipe.
JB 914 |
Daddy! Finish my car NOW!!! ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 26-September 04 From: Garden Grove, CA Member No.: 2,831 ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) i can do that voice |
Lo-Fi Version | Time is now: 8th July 2025 - 08:13 AM |
