> Don't know what happened, Any suggestions?
Carlitos Way
post Jan 24 2005, 01:40 PM
I did it MY WAY
VROOM... VROOOM, turn the corner, sputter, sputter, backfire, backfire, lose power, engine starts dying, floor the gas, downshift, sputter, sputter, backfire, backfire, back to normal for 2 blocks... then sputter, sputter, and turned it off when I got home.
Anyone venture a guess?
ArtechnikA
post Jan 24 2005, 03:31 PM
rich herzog
AAR wire loose and/or otherwise shorting to sheet metal and taking out the fuel pump -- not enough to actually blose the fuse, just enough to make it run bad.
or - more likely - loose wire at the coil.
Carlitos Way   Don't know what happened   Jan 24 2005, 01:40 PM
iiibdsiil   Water in the gas maybe?   Jan 24 2005, 01:56 PM
scott thacher   check your fuel pressure mine did that when my ret...   Jan 24 2005, 01:59 PM
!   All the abocve and/or clogged fuel filter. Have y...   Jan 24 2005, 02:00 PM
bondo   points maybe?   Jan 24 2005, 02:01 PM
Carlitos Way   Well, so far I haven't run it down to fumes th...   Jan 24 2005, 02:13 PM
SirAndy   <...   Jan 24 2005, 02:21 PM
vsg914   I agree with the clogged fuel filter theory. Mine ...   Jan 24 2005, 02:23 PM
Elliot Cannon   "It aint got no gase in it!" (Billy Bob T...   Jan 24 2005, 02:24 PM
SLITS   Which way did you turn? If it was left, the germa...   Jan 24 2005, 02:51 PM
ArtechnikA   AAR wire loose and/or otherwise shorting to sheet ...   Jan 24 2005, 03:31 PM
roundboy914   yeah, i was going to say coil wire, that thin litt...   Jan 24 2005, 05:10 PM
jwalters   http://www.914world.com/bbs2/html/e...   Jan 24 2005, 07:48 PM
Mike D.   Try sticking one of those retractable magnet thing...   Jan 25 2005, 12:58 AM
DJsRepS   Pull clean and lube put back and then ohm your tri...   Jan 25 2005, 06:11 AM
JB 914
- Lo-Fi Version Time is now: 8th July 2025 - 06:48 PM
