> 3.2l conversion died on a ride, appears I have an electrical problem, success!
jim912928
post Sep 10 2023, 01:39 PM
Took out the 914 and it just stopped cold during the drive. It appears the fuel pump is not running. I did tow it back and ran some rudimentary electrical tests (I'm not good at wiring). I get no power to the fuel pump. I then pulled the dme relay and I do get 12v on 30, 12v on 86, no voltage on 87 or 87b.
This is an 84 3.2l
thoughts?
ClayPerrine
post Sep 11 2023, 12:59 PM
DME relays have suckdilliuckucked since their invention. They were the evolution of the L-Jet double relay that was on the 914 and other VW cars.
After fixing lots of them over the years, on conversions I take the wiring out of the DME relay socket and put in sockets for two Bosch square relays. The bosch square relay is available at FLAPS, and are far cheaper than a DME relay. And way more reliable.
I did this on the 964 harness that I had in my 914-6 conversion. It works fine. The double relay is just two relays and one diode in a box. It gives the manufacturer a way to charge you more money for something simple.
jim912928   3.2l conversion died on a ride   Sep 10 2023, 01:39 PM
worn   Took out the 914 and it just stopped cold during ...   Sep 10 2023, 05:14 PM
porschetub   Took out the 914 and it just stopped cold during...   Sep 11 2023, 10:59 PM
r_towle   Two things I did after towing home my 84 911 I bou...   Sep 10 2023, 07:24 PM
jim912928   Thanks all….looked up the relay pinouts and will...   Sep 11 2023, 11:38 AM
SirAndy   +1 for the DME relay. I always carry a spare wit...   Sep 11 2023, 11:47 AM
ClayPerrine   DME relays have suckdilliuckucked since their inve...   Sep 11 2023, 12:59 PM
worn   DME relays have suckdilliuckucked since their inv...   Sep 11 2023, 05:56 PM
Steve   I read there are two sensors on the flywheel. One...   Sep 11 2023, 09:09 PM
davehg   I read there are two sensors on the flywheel. On...   Sep 11 2023, 10:56 PM
ClayPerrine   For those of you that want to get rid of the probl...   Sep 12 2023, 07:10 AM
Justinp71   Why I stick with carbs... :). No in all seriousnes...   Sep 12 2023, 08:04 AM
Steve   Why I stick with carbs... :). No in all seriousne...   Sep 12 2023, 08:23 AM
ConeDodger   Why I stick with carbs... :). No in all seriousne...   Oct 10 2023, 10:31 AM
jim912928   Ok, I jumpered 30 (always hot), to 87 and 87b and ...   Sep 12 2023, 04:33 PM
arbitrary   Ok, I jumpered 30 (always hot), to 87 and 87b and...   Sep 12 2023, 08:25 PM
r_towle   Ok, I jumpered 30 (always hot), to 87 and 87b an...   Sep 12 2023, 09:16 PM
ClayPerrine   [quote name='arbitrary' post='3101554' date='Sep ...   Sep 14 2023, 05:42 AM
jim912928   Thanks Clay for the diagrams.   Sep 12 2023, 04:54 PM
jim912928   I was testing if my fuel pump was any good (only 2...   Sep 12 2023, 09:52 PM
Steve   I was testing if my fuel pump was any good (only ...   Sep 13 2023, 09:04 AM
Root_Werks   Would think if you could do the "Y" jump...   Sep 13 2023, 08:38 AM
jim912928   Root…when I did the Y jumper the fuel pump did r...   Sep 13 2023, 04:32 PM
jim912928   Finally got back to this. Found reference video o...   Sep 18 2023, 04:43 PM
ClayPerrine   Finally got back to this. Found reference video ...   Sep 18 2023, 05:25 PM
jim912928   Thanks Clay!   Sep 18 2023, 07:59 PM
porschetub   Thanks Clay! :agree: I had the speed sensor...   Sep 19 2023, 07:22 PM
porschetub   Sorry 2 x post   Sep 20 2023, 01:37 PM
jim912928   Success! I replaced both reference sensors an...   Oct 9 2023, 03:48 PM
- Lo-Fi Version Time is now: 11th May 2025 - 03:35 PM
