jim912928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,487 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest ![]() |
Took out the 914 and it just stopped cold during the drive. It appears the fuel pump is not running. I did tow it back and ran some rudimentary electrical tests (I'm not good at wiring). I get no power to the fuel pump. I then pulled the dme relay and I do get 12v on 30, 12v on 86, no voltage on 87 or 87b.
This is an 84 3.2l thoughts? |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,668 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Would think if you could do the "Y" jumper wire trick and the fuel pump doesn't run, it's the pump or wiring to the pump. Can you supply power directly to the pump, see if it runs?
Lo-Fi Version | Time is now: 11th May 2025 - 02:41 PM |
