jim912928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,487 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest ![]() |
Took out the 914 and it just stopped cold during the drive. It appears the fuel pump is not running. I did tow it back and ran some rudimentary electrical tests (I'm not good at wiring). I get no power to the fuel pump. I then pulled the dme relay and I do get 12v on 30, 12v on 86, no voltage on 87 or 87b.
This is an 84 3.2l thoughts? |
jim912928 |
Ok, I jumpered 30 (always hot), to 87 and 87b and the fuel pump runs. Not sure if the car should start or not (it didn’t) but at least I know the fuel pump is good, the relay is bad. Ordering up 2 tonight.
arbitrary |
Member ![]() ![]() Group: Members Posts: 99 Joined: 25-April 21 From: UK Member No.: 25,475 Region Association: None ![]() ![]() |
Ok, I jumpered 30 (always hot), to 87 and 87b and the fuel pump runs. Not sure if the car should start or not (it didn’t) but at least I know the fuel pump is good, the relay is bad. Ordering up 2 tonight. I’m not certain this proves that the relay is the problem. The DME relay only powers the fuel pump when the DME senses the engine rotating; you could still have a sensor issue. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Ok, I jumpered 30 (always hot), to 87 and 87b and the fuel pump runs. Not sure if the car should start or not (it didn’t) but at least I know the fuel pump is good, the relay is bad. Ordering up 2 tonight. I’m not certain this proves that the relay is the problem. The DME relay only powers the fuel pump when the DME senses the engine rotating; you could still have a sensor issue. (IMG:style_emoticons/default/agree.gif) |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,320 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Ok, I jumpered 30 (always hot), to 87 and 87b and the fuel pump runs. Not sure if the car should start or not (it didn’t) but at least I know the fuel pump is good, the relay is bad. Ordering up 2 tonight. I’m not certain this proves that the relay is the problem. The DME relay only powers the fuel pump when the DME senses the engine rotating; you could still have a sensor issue. (IMG:style_emoticons/default/agree.gif) With DME, if the ECU sees the engine turning from the sensors, it turns on the ignition, the fuel injectors and the fuel pump. If you have spark, then It is probably the fuel pump side of the DME relay. Plug the DME relay back in, and see if you have spark. |
Lo-Fi Version | Time is now: 11th May 2025 - 03:34 PM |
