Self fixing stuff., Wondering how to keep this going. |
nivekdodge |
Sep 13 2023, 03:16 PM
Member Group: Members Posts: 250 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region |
So the gas gauge has been a sticking point. Because it's kind of important. (was going to ask if anyone had a good stick layout), i have been going back to it double checking everything. Yes, the fireman's pole had rust and it was stuck at the bottom. Yes the ohm reading were correct and i cleaned the tiny wires. at first I had nothing, then the gauge was pegged constantly. I went to take someone for a ride last night and it seems to be working. Viola!!! but it does go all over the place when you move the car. Is that normal?
I'm hoping more things start to fix themselves. Maybe leave milk and cookies out? Beer and a sandwich? Kevin |
emerygt350 |
Sep 13 2023, 06:35 PM
Advanced Member Group: Members Posts: 2,144 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
That is not right. Sounds like resistance is unpredictable across the length of the wire. If you had rust on parts there is probably other bits of corrosion around. I think that might be easier to deal with. Do you have access to a sonicator?
nivekdodge |
Sep 14 2023, 07:01 PM
That is not right. Sounds like resistance is unpredictable across the length of the wire. If you had rust on parts there is probably other bits of corrosion around. I think that might be easier to deal with. Do you have access to a sonicator? sonicator? even spellcheck questioned that. May I ask what it does? Kevin |
Montreal914 |
Sep 16 2023, 10:15 AM
Senior Member Group: Members Posts: 1,587 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
That is not right. Sounds like resistance is unpredictable across the length of the wire. If you had rust on parts there is probably other bits of corrosion around. I think that might be easier to deal with. Do you have access to a sonicator? sonicator? even spellcheck questioned that. May I ask what it does? Kevin Ultrasonic cleaner. Try Googling that, you will see. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 07:07 AM |
