Valve lash, CR pushrods / Crusty method |
rfinegan |
Sep 18 2023, 07:40 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Is it me, or does using the crusty method to adjust the valve lash on anything but a stock cam difficult with overlaps found in Larger Web cam?
Zero Loose gap=no play but can still turn the pushrods or Elephant feet rocker tips I still let a little ticking if both valves are not “rocking” perfect? |
rfinegan |
Sep 18 2023, 10:56 AM
Yep I get the shared lobe, but doing an the intake and the exhaust at the same time?
MY old method was to rotate each valve one at a time it was full open and adjust the other side. Not as fast but seems to get the results I as looking for |
ClayPerrine |
Sep 18 2023, 11:50 AM
Life's been good to me so far..... Group: Admin Posts: 15,502 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
MY old method was to rotate each valve one at a time it was full open and adjust the other side. I have always done it this way. I make sure the exhaust valve on the right is fully open, then adjust the exhaust valve on the left side. Repeat until you complete one side. Then repeat on the other side. Never had an issue with valve adjustments after I started doing it this way. Just my $.02 |
Lo-Fi Version | Time is now: 1st June 2024 - 05:23 PM |
