Need help wiring headlights/parking |
sixaddict |
Sep 10 2023, 03:13 PM
Senior Member Group: Members Posts: 807 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Purchased and installing 914 rubber headlight /parking light harness.(markers deleted)
Admittedly poor technician especially electrical so need some help. Most are clear cut but believe I have isolated problem. On passenger side there are two wires (gray with red line) and ON drivers gray with black line) Trying to figure if those should be together or separated….(meaning all 4) Yesterday I did pass side…..had headlights and parking but no signals. Today I did drivers side and have no headlights but have 4 way flashers. Also appears drivers side flasher is on parking light side of bulb and parking lt on turn signal/flasher part of filament as its very bright. Obviously I have it wrong. Appreciate any help. TIA |
Dave_Darling |
Sep 18 2023, 01:46 AM
There is only one flasher relay; it is used for all of the lights that blink.
The four-way hazards power the bulbs and relay a different way than the turn signals do. (For one thing, the ignition needs to be on for the turn signals to flash. If it's off, you get the non-flashing "parking light" feature instead.) I don't remember the different paths without digging through the wiring diagram. --DD |
sixaddict |
Sep 18 2023, 01:27 PM
Thanks Dave.
Yep have ignition on…..but no turn signals…..either end. Or brake lights for that matter. There is only one flasher relay; it is used for all of the lights that blink. The four-way hazards power the bulbs and relay a different way than the turn signals do. (For one thing, the ignition needs to be on for the turn signals to flash. If it's off, you get the non-flashing "parking light" feature instead.) I don't remember the different paths without digging through the wiring diagram. --DD |
Lo-Fi Version | Time is now: 15th June 2024 - 11:12 AM |
