Name is Snick |
Newbie ![]() Group: Members Posts: 15 Joined: 28-August 23 From: NoVa Member No.: 27,550 Region Association: None ![]() |
This is on a 912E but I guess it’s the same on a 914.
Do I have to remove the Alternator pulley to get the fan belt off? The adjustment doesn’t seem to adjust far enough to get the belt off. Thanks |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Sometimes a fat flathead screw driver on the alternator pulley resting on the outer surface of the pulley and under the belt.
Then rotate the pulley to move the screw driver further under the belt and the belt will pop off |
Name is Snick |
Sometimes a fat flathead screw driver on the alternator pulley resting on the outer surface of the pulley and under the belt. Then rotate the pulley to move the screw driver further under the belt and the belt will pop off Doing the screw driver under the belt method requires that you have a way to turn the crankshaft/fan to advance the belt otherwise the belt doesn’t move. I can turn the alternator pully but the belt doesn’t move. Is there a tool to turn the crankshaft manually? Thanks for any help Snick |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,169 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Sometimes a fat flathead screw driver on the alternator pulley resting on the outer surface of the pulley and under the belt. Then rotate the pulley to move the screw driver further under the belt and the belt will pop off Doing the screw driver under the belt method requires that you have a way to turn the crankshaft/fan to advance the belt otherwise the belt doesn’t move. I can turn the alternator pully but the belt doesn’t move. Is there a tool to turn the crankshaft manually? Thanks for any help Snick (IMG:style_emoticons/default/welcome.png) Any or all of the above should get you there. Is the belt loose or cracked? is the alternator putting out |
Name is Snick |
Sometimes a fat flathead screw driver on the alternator pulley resting on the outer surface of the pulley and under the belt. Then rotate the pulley to move the screw driver further under the belt and the belt will pop off Doing the screw driver under the belt method requires that you have a way to turn the crankshaft/fan to advance the belt otherwise the belt doesn’t move. I can turn the alternator pully but the belt doesn’t move. Is there a tool to turn the crankshaft manually? Thanks for any help Snick (IMG:style_emoticons/default/welcome.png) Any or all of the above should get you there. Is the belt loose or cracked? is the alternator putting out trying to get belt off to run eng without alternator to see it the noise is alternator bearing noise or eng noise. Thanks |
Lo-Fi Version | Time is now: 10th July 2025 - 08:37 AM |
