Name is Snick |
Newbie ![]() Group: Members Posts: 15 Joined: 28-August 23 From: NoVa Member No.: 27,550 Region Association: None ![]() |
This is on a 912E but I guess it’s the same on a 914.
Do I have to remove the Alternator pulley to get the fan belt off? The adjustment doesn’t seem to adjust far enough to get the belt off. Thanks |
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,011 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Jack up one side, put it in 5th, roll a tire.
Since your engine is in backwards;), you should be able to get a socket on the crank too. |
Name is Snick |
Jack up one side, put it in 5th, roll a tire. Since your engine is in backwards;), you should be able to get a socket on the crank too. That 5th gear thing sounded good, so I tried it. I would need 3 men and a boy to rotate the tire. It won't budge. I like all of the well-thought-out suggestions. I like the 90 mph one. But my car won't go 90 mph. Any yes, I could cut the belt with a pocket knife, but I plan to put it back on unless I can get a new one. keep the suggestions coming. Maybe one will work. Thanks |
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,076 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
Jack up one side, put it in 5th, roll a tire. Since your engine is in backwards;), you should be able to get a socket on the crank too. That 5th gear thing sounded good, so I tried it. I would need 3 men and a boy to rotate the tire. It won't budge. I like all of the well-thought-out suggestions. I like the 90 mph one. But my car won't go 90 mph. Any yes, I could cut the belt with a pocket knife, but I plan to put it back on unless I can get a new one. keep the suggestions coming. Maybe one will work. Thanks Well it should have. Check you don’t have the e-brake on. If it is not moving I’d be looking for the reason why. |
Name is Snick |
Jack up one side, put it in 5th, roll a tire. Since your engine is in backwards;), you should be able to get a socket on the crank too. That 5th gear thing sounded good, so I tried it. I would need 3 men and a boy to rotate the tire. It won't budge. I like all of the well-thought-out suggestions. I like the 90 mph one. But my car won't go 90 mph. Any yes, I could cut the belt with a pocket knife, but I plan to put it back on unless I can get a new one. keep the suggestions coming. Maybe one will work. Thanks Well it should have. Check you don’t have the e-brake on. If it is not moving I’d be looking for the reason why. You were right. I tried again. It was very hard to get it to move at first. But I could move it an inch at a time after it moved. Just enough. The good news is the noise is not the engine, must be the alternator bearing Bad news is now I have to get alternator out. Do you know if you have to remove any tin? The bottom bolt is loose as is the adjuster bolt but I can't move the alternator. thanks |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,169 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Jack up one side, put it in 5th, roll a tire. Since your engine is in backwards;), you should be able to get a socket on the crank too. That 5th gear thing sounded good, so I tried it. I would need 3 men and a boy to rotate the tire. It won't budge. I like all of the well-thought-out suggestions. I like the 90 mph one. But my car won't go 90 mph. Any yes, I could cut the belt with a pocket knife, but I plan to put it back on unless I can get a new one. keep the suggestions coming. Maybe one will work. Thanks Well it should have. Check you don’t have the e-brake on. If it is not moving I’d be looking for the reason why. You were right. I tried again. It was very hard to get it to move at first. But I could move it an inch at a time after it moved. Just enough. The good news is the noise is not the engine, must be the alternator bearing Bad news is now I have to get alternator out. Do you know if you have to remove any tin? The bottom bolt is loose as is the adjuster bolt but I can't move the alternator. thanks Yes. A couple years ago I was getting ready for a long weekend in the Poconos and the alternator was making a racket. It was a bit challenging, but I got her switched out without removing any tin. As I recall, it did not come out easy Do you have a Haynes or Clymer manual? |
Name is Snick |
Jack up one side, put it in 5th, roll a tire. Since your engine is in backwards;), you should be able to get a socket on the crank too. That 5th gear thing sounded good, so I tried it. I would need 3 men and a boy to rotate the tire. It won't budge. I like all of the well-thought-out suggestions. I like the 90 mph one. But my car won't go 90 mph. Any yes, I could cut the belt with a pocket knife, but I plan to put it back on unless I can get a new one. keep the suggestions coming. Maybe one will work. Thanks Well it should have. Check you don’t have the e-brake on. If it is not moving I’d be looking for the reason why. You were right. I tried again. It was very hard to get it to move at first. But I could move it an inch at a time after it moved. Just enough. The good news is the noise is not the engine, must be the alternator bearing Bad news is now I have to get alternator out. Do you know if you have to remove any tin? The bottom bolt is loose as is the adjuster bolt but I can't move the alternator. thanks Yes. A couple years ago I was getting ready for a long weekend in the Poconos and the alternator was making a racket. It was a bit challenging, but I got her switched out without removing any tin. As I recall, it did not come out easy Do you have a Haynes or Clymer manual? I have Clymer which has minimal on removing Alternator. Main helpful thing I got from it is I have to remove the heat exchanger. Long day flat on back for oxygenarian. Thanks |
Lo-Fi Version | Time is now: 10th July 2025 - 08:42 AM |
