Painted shroud |
Painted shroud |
StratPlayer |
Oct 12 2023, 02:01 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Got my oil cooler shroud painted, it was black decided to paint it the same color as the car. I like it much better.
Attached image(s) |
VaccaRabite |
Oct 12 2023, 02:23 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Have you found that you need it?
I have a passive Setrab cooler behind the pass side rear axle and I've not seen oil temps go over about 205. How are your temps on the 2.3 with the front mount oil cooler? Zach |
StratPlayer |
Oct 12 2023, 03:34 PM
Have you found that you need it? I have a passive Setrab cooler behind the pass side rear axle and I've not seen oil temps go over about 205. How are your temps on the 2.3 with the front mount oil cooler? Zach Zach I haven’t seen my oil temps get above 180, just took the car on a road-trip to steamboat springs and back oil temp stayed the same whole trip. |
914_teener |
Oct 12 2023, 04:59 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Have you found that you need it? I have a passive Setrab cooler behind the pass side rear axle and I've not seen oil temps go over about 205. How are your temps on the 2.3 with the front mount oil cooler? Zach Zach I haven’t seen my oil temps get above 180, just took the car on a road-trip to steamboat springs and back oil temp stayed the same whole trip. Oh my....are you sure you need it. Those temps may not be hot enough to dissipate out moisture. A thermistor bypass? |
Lo-Fi Version | Time is now: 10th June 2024 - 06:52 AM |
