Center Console Gauge Temperature? |
jackspratt |
Oct 21 2023, 12:44 PM
Member Group: Members Posts: 55 Joined: 5-February 22 From: Canada Member No.: 26,315 Region Association: Pacific Northwest |
Hi all,
Was driving around first time. The center console gauge that says temp just comes up to the first white line. Doesn't seem to move past that at all when driving for 1/2 hour or so. Is this normal ? And if not. How do I get it to work or function properly for what it's there for? Talking 1973 dual carbs, 2056 Thanks!!! Attached image(s) |
bdstone914 |
Oct 22 2023, 01:34 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@jackspratt
If that is where the needle is when the ignition is on you ate not gettimg any signal to the gauge. The sender wire runs from the sender to a connector on the passenger side of the engine bay. If you ground the wire it should peg the gauge hot. If you do not get the needle to move chevk for power and ground at the gauge. |
Lo-Fi Version | Time is now: 10th June 2024 - 09:54 AM |
