Center Console Gauge Temperature? |
jackspratt |
Oct 21 2023, 12:44 PM
Member Group: Members Posts: 55 Joined: 5-February 22 From: Canada Member No.: 26,315 Region Association: Pacific Northwest |
Hi all,
Was driving around first time. The center console gauge that says temp just comes up to the first white line. Doesn't seem to move past that at all when driving for 1/2 hour or so. Is this normal ? And if not. How do I get it to work or function properly for what it's there for? Talking 1973 dual carbs, 2056 Thanks!!! Attached image(s) |
Craigers17 |
Oct 22 2023, 05:01 AM
Senior Member Group: Members Posts: 749 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
Based on your type of gauge, if the needle were going a little past the very first/starting line, you could be approaching 180. I'm not sure how cold it is in your part of Canada right now, but I could believe that number is theoretically possible. If it is right at that line or below, ...then something is probably not right.
I'd make sure it is connected. First I would check the connection under the engine where the sender is....here:(in this pic, it may or may not have a cover on it as well) If it is connected there, you might make sure that the gauge itself is connected and trace that back .....I THINK it is spliced into the harness a few feet from the console....but hopefully someone will correct me if I'm wrong. |
stownsen914 |
Oct 22 2023, 07:06 AM
Senior Member Group: Members Posts: 916 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
When you say it goes to the white line ... does it move at all past the "key on" position?
jackspratt |
Oct 22 2023, 11:35 PM
Lo-Fi Version | Time is now: 10th June 2024 - 03:56 AM |
