Center Console Gauge Temperature? |
jackspratt |
Oct 21 2023, 12:44 PM
Member Group: Members Posts: 55 Joined: 5-February 22 From: Canada Member No.: 26,315 Region Association: Pacific Northwest |
Hi all,
Was driving around first time. The center console gauge that says temp just comes up to the first white line. Doesn't seem to move past that at all when driving for 1/2 hour or so. Is this normal ? And if not. How do I get it to work or function properly for what it's there for? Talking 1973 dual carbs, 2056 Thanks!!! Attached image(s) |
930cabman |
Oct 21 2023, 05:24 PM
Advanced Member Group: Members Posts: 3,149 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Maybe try an infrared gun pointed at the sump?
Or pull the sender and drop it into boiling water |
jackspratt |
Oct 21 2023, 09:48 PM
fiacra |
Oct 22 2023, 07:45 AM
Person.Woman.Man.Camera.TV Group: Members Posts: 345 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
Maybe try an infrared gun pointed at the sump? Or pull the sender and drop it into boiling water ? To further explain what I believe @930cabman is telling you: You can use a digital infrared thermometer to check temperature at the sump where the temperature sensor is located. Here's an example of one: https://www.homedepot.com/p/Klein-Tools-Inf...1-IR1/313516785 These are also useful for a number of other things, such as checking for uniform brake temperature, checking for heat loss in your home heating ducts, etc... You can pull the sensor and drop it in boiling water to see what the gauge reads. Depending upon the altitude it should read 212 degrees fahrenheit/100 degrees celsius. This thread should help you with checking the thermostat bellows: http://www.914world.com/bbs2/index.php?showtopic=350498 |
jackspratt |
Oct 22 2023, 11:40 PM
Maybe try an infrared gun pointed at the sump? Or pull the sender and drop it into boiling water ? To further explain what I believe @930cabman is telling you: You can use a digital infrared thermometer to check temperature at the sump where the temperature sensor is located. Here's an example of one: https://www.homedepot.com/p/Klein-Tools-Inf...1-IR1/313516785 These are also useful for a number of other things, such as checking for uniform brake temperature, checking for heat loss in your home heating ducts, etc... You can pull the sensor and drop it in boiling water to see what the gauge reads. Depending upon the altitude it should read 212 degrees fahrenheit/100 degrees celsius. This thread should help you with checking the thermostat bellows: http://www.914world.com/bbs2/index.php?showtopic=350498 thanks, ill look into this too |
Lo-Fi Version | Time is now: 10th June 2024 - 07:39 AM |
