Idle issues, anyone want to take a stab?, sound up |
nivekdodge |
Oct 26 2023, 09:36 AM
Member Group: Members Posts: 250 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region |
https://www.youtube.com/shorts/P82FcOy9scY
914 with fresh 1.8 and 123 distributor. Idle jets were swapped around , no change. only seems to happen on #4. Notice the pooof in the barrel when it pops? Kevin |
rhodyguy |
Oct 26 2023, 10:53 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Use 1 idle speed adj screw to raise the idle a bit and remeasure the flow across all 4 Venturi. The other ISAS should be off the stop. Then report back with #s. At what rpm does the ‘sneeze’ cease?. What rpm is your idle set at?
Lo-Fi Version | Time is now: 10th June 2024 - 04:11 AM |
