Oil leaking from the oil cooler, Procedure question |
Txbentleyboy |
Oct 31 2023, 05:50 PM
Member Group: Members Posts: 73 Joined: 15-October 16 From: Davidson County, NC, USA Member No.: 20,498 Region Association: MidAtlantic Region |
Does the engine need to be removed to change the seals?
Any and all thoughts are appreciated! |
emerygt350 |
Oct 31 2023, 07:03 PM
Advanced Member Group: Members Posts: 2,156 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Having just done both a seal change while in the car and a whole engine drop with cooler replacement (and a quick 2056 upgrade), I would have to say go for both. Replacing the seals in the car was super easy, and if that is the only thing wrong, go for it. However, I replaced my seals in about an hour only to find that in fact my cooler was cracked...
So, if you are confident it is the seals, just slide the cooler back, pop in the new ones, and call it a day. If you are not sure... well, in the time it took you to replace the seals you could have dropped the engine. I only suggest the easy no drop because if you do drop the engine you could have issues with old brittle wiring etc. |
Lo-Fi Version | Time is now: 17th June 2024 - 01:40 PM |
