New 914-4 rear brake pads? |
Tom1394racing |
Nov 15 2023, 02:12 PM
Member Group: Members Posts: 297 Joined: 25-August 07 From: CT Member No.: 8,039 Region Association: North East States |
What rear pads should I use that will fit the thick top caliper retaining pin? All the pads I see that match the 914-352-923-01 P/N seem to show the small lug hole on the pads. I would like to avoid having to enlarge the top hole on the pads.
mskala |
Nov 16 2023, 05:14 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
The 914-6 rear pads are the same size as the 914-4 front pads (early I think? instead of late).
So, you can either find 2 more small pins (1 for each side) or just turn down the ones you have in a lathe. Back in the day I bought the PMB Aluminum copy of the 914-6 rear calipers and made some aluminum pins (to save weight (IMG:style_emoticons/default/biggrin.gif) ) (All thin pins to fit the standard holes) Mark S. |
Tom1394racing |
Nov 17 2023, 09:01 AM
The 914-6 rear pads are the same size as the 914-4 front pads (early I think? instead of late). So, you can either find 2 more small pins (1 for each side) or just turn down the ones you have in a lathe. Back in the day I bought the PMB Aluminum copy of the 914-6 rear calipers and made some aluminum pins (to save weight (IMG:style_emoticons/default/biggrin.gif) ) (All thin pins to fit the standard holes) Mark S. Thanks Mark I have several NOS sets of SWB 911 pads. I took one set and drilled out the holes with my drill press. Seemed easy enough and fit well. However, my rebuilt calipers from PMB came without the inner adjusters. I am waiting for a set from them. |
Lo-Fi Version | Time is now: 10th June 2024 - 11:12 AM |
