| Ottomotion |
Nov 17 2023, 04:53 PM
Member ![]() ![]() Group: Members Posts: 73 Joined: 12-January 23 From: Central California Member No.: 27,090 Region Association: None |
Have a set of 2L fuchs that have been painted with black in the 'low spokes'.
I prefer the factory all metal look. Wondering about recommendations for paint removal. Chemical? Pressure wash? Obviously want to retain the stock look without damaging the underlying alloy. What would you do? Thanks.... |
| Ottomotion |
Nov 17 2023, 11:53 PM
Thanks for the feedback. They are factory and the black seems to be chipped in a few places so i am thinking oven cleaner is a good bet. Just didn't want to ruin them without checking here first.... (IMG:style_emoticons/default/beerchug.gif)
| mepstein |
Nov 18 2023, 05:52 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,915 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Thanks for the feedback. They are factory and the black seems to be chipped in a few places so i am thinking oven cleaner is a good bet. Just didn't want to ruin them without checking here first.... (IMG:style_emoticons/default/beerchug.gif) I would start off with less harsh chemicals first. No reason to strip off the factory anodizing if you don’t need too - unless the factory anodizing has failed and then you might as well go all in. |
| porschetub |
Nov 18 2023, 12:38 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,172 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Thanks for the feedback. They are factory and the black seems to be chipped in a few places so i am thinking oven cleaner is a good bet. Just didn't want to ruin them without checking here first.... (IMG:style_emoticons/default/beerchug.gif) I would start off with less harsh chemicals first. No reason to strip off the factory anodizing if you don’t need too - unless the factory anodizing has failed and then you might as well go all in. (IMG:style_emoticons/default/agree.gif) I would put oven cleaner near them ....please don't plenty of safer ways ,if anodized it will sand off with wet and dry. |
Ottomotion Paint Removal From 2.0 Fuchs? Nov 17 2023, 04:53 PM
mepstein Good chance it was rattle can and may come off pre... Nov 17 2023, 05:53 PM
brant Are they aftermarket Fuchs ?
Could be baked finish... Nov 17 2023, 07:30 PM
brant Half of them Nov 17 2023, 07:32 PM
JeffBowlsby I recall cleaning up a set with acetone. I think ... Nov 17 2023, 09:57 PM
Unpretentious I used Klean Strip, available at Home Depot etc., ... Nov 18 2023, 12:13 AM
dhuckabay Two bits here. Oven cleaner as pointed out above ... Nov 18 2023, 12:43 PM
brant It’s great for anything that you intend to polis... Nov 18 2023, 01:02 PM
technicalninja The trick for using lye on aluminum stuff is to no... Nov 18 2023, 01:40 PM
technicalninja Safety tips:
Oven cleaner: you need variable airf... Nov 18 2023, 01:59 PM
Ottomotion What about using a heat gun? Nov 18 2023, 08:01 PM
technicalninja Heat will help the cleaners work.
Heat by itself ... Nov 19 2023, 12:36 AM
Mikey914 Heat is a good way to go. Don't use oven clean... Nov 20 2023, 12:47 AM
Unpretentious I should have been clearer in my earlier response.... Nov 20 2023, 10:09 PM
MikeK Since CA and CO have banned MEK, I've found th... Nov 21 2023, 07:46 AM
Jett I bought some citrusstrip and am going to try it o... Nov 21 2023, 12:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th September 2026 - 01:05 AM |
