> Oil Leaks, I am tired of them
sdoolin
post Nov 19 2023, 01:57 PM
Rebuilt my 2.0 back in 2016. Full "Raby Spec" 2056. Runs very well. It is out of the car right now as I am dealing with a rusty battery tray (separate thread on that). It appears that I have leaks at most/all of the pushrod tube seals, the valve cover seals, and the rear main seal. This is not a surprise to me, I clean the bottom of the engine regularly, and knew this day was coming
Pretty sure I used the Victor Reinz gasket set that came with my engine "kit" from the Type IV Store. I used the cork valve cover seals from the Victor Reinz set. I did not use any RTV anywhere. Hate the stuff. I know I used a rear main seal from GoWesty as someone back then had suggested it is a better part then what is included with the Victor Reinz set.
I installed new pushrod tubes and used the O-Rings from the Victor Reinz set.
Does anyone really have an oil tight VW Type IV engine? If yes, how does none do that?
ctc911ctc
post Nov 20 2023, 02:39 PM
'74 2.0, 28k miles
I tried to tighten the leaks with the engine in the car, 4-5 tries and then I took the engine out, tore near everything off (cylinders stayed on) and cleaned and cleaned and cleaned until all of the oil marks were removed. (IMG:style_emoticons/default/evilgrin.gif)
all rubber/synthetic(?) seals were replaced: front/rear, the most important oil cooler seals, and all of the push-rod seals. I bought a few new push rod tubes, a couple were bent and well, did not look very good. I did not use any LTV for anything because of the high operating temperature. (this is an opinion only). I used Permatex 80017 to secure the push-rod tubes seals and the others so when placed into position they stay in that position, and it may provide that little bit extra sealant. Though the odor is not very good I have had good results with Permatex - I think sealants, after I have had a few years of experience with them, is a matter of learning how to use the one of choice, all are a bit nuanced (again, opinion) and one persons perfect sealant is another persons evil sealant. (IMG:style_emoticons/default/confused24.gif)
The engine has been in for 2 years, not a leak. I did have one or two of the push-rod tubes start seeping in the beginning, I removed them with the engine in the car and then re-sealed with great success. (IMG:style_emoticons/default/piratenanner.gif)
Not a drop on my garage floor. (IMG:style_emoticons/default/beerchug.gif)
CTC911CTC
sdoolin   Oil Leaks   Nov 19 2023, 01:57 PM
Shivers   That is the rumor. My last T-4 build didn’t leak...   Nov 19 2023, 02:26 PM
914sgofast2   Jake Raby did a video about his frustration in fin...   Nov 19 2023, 02:43 PM
930cabman   My 2056 build has a couple smallish pushrod tubes ...   Nov 19 2023, 05:12 PM
Geezer914   I have a 26mm type 1 CB performance oil pump that ...   Nov 19 2023, 05:27 PM
JeffBowlsby   Jake also used to recommend plumbers pipe dope wit...   Nov 19 2023, 05:59 PM
Literati914   what about the spring loaded tubes, effective or n...   Nov 19 2023, 06:10 PM
Shivers   what about the spring loaded tubes, effective or ...   Nov 19 2023, 08:14 PM
AZBanks   what about the spring loaded tubes, effective or...   Nov 19 2023, 10:34 PM
burton73   [quote name='Shivers' post='3113735' date='Nov 19...   Dec 1 2023, 01:05 PM
barefoot   For push rod tube seals, I didn't use the gree...   Nov 20 2023, 07:57 AM
Geezer914   McMaster-Carr chemical resistant viton fluoroelast...   Nov 20 2023, 08:04 AM
sdoolin   McMaster-Carr chemical resistant viton fluoroelas...   Nov 20 2023, 09:10 AM
VaccaRabite   I always fight with pushrod tube seals. You have ...   Nov 20 2023, 08:59 AM
sdoolin   Thanks for all replies... I have tried to find th...   Nov 20 2023, 09:48 AM
Geezer914   Thanks for all replies... I have tried to find t...   Nov 20 2023, 10:44 AM
FlacaProductions   Nice: Here's the direct links - 212: https://...   Nov 20 2023, 10:57 AM
Geezer914   I had a pair of cast aluminium valve covers and it...   Nov 20 2023, 11:36 AM
technicalninja   Took a bit to find the x shaped viton rings. this...   Nov 20 2023, 12:11 PM
914werke   what is the current group-think regarding bolt o...   Nov 20 2023, 12:22 PM
sdoolin   what is the current group-think regarding bolt ...   Nov 20 2023, 12:43 PM
sdoolin   Thank you geezer for the explicit instructions - v...   Nov 20 2023, 12:40 PM
technicalninja   Jake Raby did a video about his frustration in fi...   Nov 20 2023, 12:48 PM
Jack Standz   The silicone valve cover gaskets Aircooled.Net use...   Nov 20 2023, 12:59 PM
sdoolin   The silicone valve cover gaskets Aircooled.Net us...   Nov 20 2023, 01:07 PM
porschetub   [quote name='Jack Standz' post='3113835' date='No...   Dec 2 2023, 03:31 PM
sdoolin   [quote name='sdoolin' post='3113836' date='Nov 21...   Dec 2 2023, 06:46 PM
VaccaRabite   Regular valve covers work fine. You don't nee...   Nov 20 2023, 01:43 PM
ctc911ctc   '74 2.0, 28k miles I tried to tighten the lea...   Nov 20 2023, 02:39 PM
Geezer914   Second that, Permatex Hi Tac gasket cement on the ...   Nov 20 2023, 03:02 PM
FlacaProductions   The VW logo on the cover goes UPSIDE DOWN when the...   Nov 20 2023, 03:37 PM
bkrantz   The truly leak-free type 4 engine might be a fanta...   Nov 20 2023, 08:53 PM
brant   pushrod seals are an o ring... they are designed t...   Nov 21 2023, 10:50 AM
wonkipop   pushrod seals are an o ring... they are designed ...   Nov 22 2023, 01:15 AM
sdoolin   pushrod seals are an o ring... they are designed ...   Dec 1 2023, 06:22 PM
burton73   pushrod seals are an o ring... they are designed...   Dec 9 2023, 02:41 PM
sdoolin   Still working on teardown, finding pretty much wha...   Nov 30 2023, 07:08 PM
Porschef   Really despise oil leaks. I suppose owning an air ...   Dec 1 2023, 06:36 AM
Olympic 914   Wow those tubes look nice. don't think I want...   Dec 1 2023, 01:13 PM
Jack Standz   Wow those tubes look nice. don't think I wan...   Dec 1 2023, 01:31 PM
Literati914   [quote name='AZBanks' post='3113747' date='Nov 19...   Dec 1 2023, 01:21 PM
sdoolin   I have ordered new pushrod tubes from TIVStore, ha...   Dec 1 2023, 06:19 PM
Geezer914   DuPont Moly coat 55 O ring grease!   Dec 2 2023, 07:19 AM
sdoolin   DuPont Moly coat 55 O ring grease! I have a...   Dec 2 2023, 06:34 PM
Front yard mechanic   It’s called controled seepage   Dec 2 2023, 08:17 AM
Literati914   ..Just looked closer at the above pushrod tubes. ...   Dec 2 2023, 03:45 PM
ClayPerrine   ..Just looked closer at the above pushrod tubes....   Dec 3 2023, 09:07 AM
sdoolin   [quote name='Literati914' post='3115770' date='De...   Dec 4 2023, 09:02 AM
Dave_Darling   OK and there's multiple options for these on ...   Dec 9 2023, 12:55 PM
sdoolin   Spent all day cleaning. Have a pretty good contact...   Dec 2 2023, 06:42 PM
Geezer914   Did you install the engine with these covers? I h...   Dec 3 2023, 08:54 AM
sdoolin   Thinking about phenolic spacers, the spacers betwe...   Dec 4 2023, 09:24 AM
Superhawk996   Or . . . wait for it . . . Longer studs?   Dec 4 2023, 09:47 AM
sdoolin   Or . . . wait for it . . . Longer studs? OK, I ...   Dec 4 2023, 05:12 PM
Geezer914   If running carbs you should run phelonic spacers t...   Dec 4 2023, 12:35 PM
brant   Longer studs for carbs is a standard thing You wi...   Dec 4 2023, 03:40 PM
sdoolin   Longer studs for carbs is a standard thing You w...   Dec 4 2023, 05:11 PM
Superhawk996   [quote name='brant' post='3116066' date='Dec 4 20...   Dec 8 2023, 12:05 PM
sdoolin   Belmetric is always a good 1st choice https://b...   Dec 8 2023, 01:42 PM
sdoolin   More cleaning, inspection, and beginning of re-ass...   Dec 8 2023, 12:00 PM
rhodyguy   You are running the shorter version of intake mani...   Dec 8 2023, 12:30 PM
sdoolin   Attempts to remove existing intake studs have fail...   Dec 9 2023, 10:17 AM
Superhawk996   Collet style stud install and removal tools specif...   Dec 9 2023, 12:20 PM
sdoolin   Thank you Superhawk996 - which reminds of two diff...   Dec 9 2023, 01:43 PM
porschetub   Thank you Superhawk996 - which reminds of two dif...   Dec 18 2023, 08:37 PM
sdoolin   More re-assembly today. The special "X-Ring...   Dec 18 2023, 06:50 PM
Dave_Darling   I do not like the bolt-on valve covers for our eng...   Dec 20 2023, 03:20 PM
rjames   I do not like the bolt-on valve covers for our en...   Dec 20 2023, 03:28 PM
porschetub   I do not like the bolt-on valve covers for our en...   Dec 20 2023, 05:54 PM
sdoolin   I finally received the CB Performance bolt on valv...   Jan 2 2024, 01:48 PM
Jack Standz   Available for approximately $20 to $25 f...   Jan 2 2024, 02:35 PM
ericoneal   I'm up the road from you in Crestwood and have...   Jan 2 2024, 08:18 PM
sdoolin   I'm up the road from you in Crestwood and hav...   Jan 3 2024, 11:23 AM
technicalninja   I have one of those flywheel locks. I've had i...   Jan 3 2024, 12:05 PM
sdoolin   I have one of those flywheel locks. I've had ...   Jan 3 2024, 01:02 PM
Dave_Darling   I've used a wrench over one of the clutch moun...   Jan 5 2024, 01:56 AM
sdoolin   Just about ready to go back into the car. I know t...   Jan 13 2024, 06:55 PM
sdoolin   Progress has been slow. Many excuses. But very clo...   Mar 10 2024, 11:54 AM
technicalninja   Nicely done! Really like your "shop...   Mar 10 2024, 01:28 PM
sdoolin   Nicely done! Really like your "shop...   Mar 11 2024, 07:33 AM
FlacaProductions   Green/red is oil pressure sender idiot light.   Mar 10 2024, 01:36 PM
sdoolin   Green/red is oil pressure sender idiot light. T...   Mar 11 2024, 07:37 AM
Dave_Darling   [quote name='sdoolin' date='Mar 11 202...   Mar 11 2024, 08:40 PM
sdoolin   [quote name='sdoolin' date='Mar 11 20...   Mar 12 2024, 08:28 AM
DRPHIL914   @sdoolin did anyone every address your question ...   Mar 11 2024, 07:23 AM
sdoolin   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Mar 11 2024, 07:39 AM
sdoolin   I (finally) have the engine back in the car. I hav...   Mar 27 2024, 11:41 AM
930cabman   I (finally) have the engine back in the car. I ha...   Mar 27 2024, 12:19 PM
Dave_Darling   If the difference is about 1 3/4", it would b...   Mar 27 2024, 02:03 PM
sdoolin   If the difference is about 1 3/4", it would ...   Mar 27 2024, 02:16 PM
bkrantz   Yup, enough play in the exhaust pipe connections t...   Mar 27 2024, 09:40 PM
sdoolin   Loosened everything up, removed the heater ducts a...   Mar 29 2024, 07:22 AM
GBX0073   Great Picture Looking good !   Mar 29 2024, 08:30 AM
technicalninja   :agree: :agree: :agree: Nice and clean! M...   Mar 29 2024, 09:36 AM
sdoolin   Thanks for the compliments in the cleanliness. But...   Mar 30 2024, 07:52 AM
technicalninja   Post a pic of your leak point please. Really stra...   Mar 30 2024, 08:39 AM
technicalninja   You're going to need a mirror with all the stu...   Mar 30 2024, 08:52 AM
sdoolin   Pic below. Hard to get a good picture but you can ...   Mar 30 2024, 09:27 AM
technicalninja   I'd first clean all the oil with B12 carb spra...   Mar 30 2024, 10:05 AM
technicalninja   You're running carbs... My 75 came with a bra...   Mar 30 2024, 10:42 AM
- Lo-Fi Version Time is now: 21st October 2026 - 08:22 PM
