914-6 Engine Serial Number, Does Not Have One |
jrrobertson |
Dec 6 2023, 01:19 PM
Newbie Group: Members Posts: 30 Joined: 28-December 16 From: Wolverine Lake , Michigan Member No.: 20,704 Region Association: Upper MidWest |
I have only posted a few times on the World so forgive me if I screw this up.
For the last four years I have been attempting to restore a 1971 914-6 to as original condition as I can. The question I have today is regarding the engine serial number. According to the COA it should be 6414134. As shown in the pictures below it appears not have a serial number. What are your thoughts on this? The original engine blew up needing a new case? I did notice that two of the connecting rods looked slightly different (all weighed the same). Could it have thrown a rod and been rebuilt with a new case using all the other original parts? Thank you for your thoughts. Also, anyone know where the engine numbered 6414134 is? A long shot but I thought I would ask. |
rgalla9146 |
Dec 6 2023, 02:02 PM
Advanced Member Group: Members Posts: 4,563 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
To the right of your crank pulley there is a vertical surface that supports the fan
housing. Looking from the right you may see stamped in numbers. Just behind there, on the horizontal surface you might find a type number such as 901/-- or 911/-- IF you find numbers there it is a 911 engine. If there are no numbers there or on the horizontal surface near the thermostat / flyheel you have a replacement block. Shown are correct 914 6 engine identification numbers Attached thumbnail(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 11:56 PM |
