> Show me your heater blower Y splitter set up
DC_neun_vierzehn
post Dec 4 2023, 04:10 PM
I bought AA's heater blower update kit with the Y splitter and installed it over the weekend. The hose that goes over to the passenger side is very long. I'm interested ins seeing how others have that hose secured as it goes over the engine from the motor to the passenger side.
I'm guessing zip ties are used? My fear is that having it loose and flopping around in the engine bay, it could get sucked into the cooling fan (and it just looks bad).
If you have this set up, please kindly share a pic of how you ran that hose from the motor to the passenger side?
TYIA
wonkipop
post Dec 6 2023, 02:31 AM
i think there is some kind of idea out there that the y set up and twin hoses was an official option.
i can find no evidence of that what so ever when searching parts manuals etc.
what i can find is that early 914s had the VW 411 set up with a more or less central fan and two hoses from the 4 and 2 door 411 sedans. and i believe in 73 it reverts for 914s to an adaption of the 411/412 variant (squareback) set up where they just use one hose biased to the drivers side - primarily for defrost of windscreen which is all the fan really needed to do.
i think what happened is that dealers maybe, and certainly those in the know, knew was that you could use the VW 411/412 variant fan hose splitter to do a twin hose set up on cars post 73.
but as i say i can find no evidence factory did it.
all the parts to do the twin hose post 73 set up are from the VW 411 variant
they did not need to worry about the hose blocking the fan in the VW model because the fan was sealed into a boot for intake air. the heater blower hose was draped over the top of the boot.
and in the earlier twin hose set up with central fan the fan was mounted high and centrally off a bracket that kept both fan and hoses clear of fan intake.
i would never personally want to do a twin hose set up on my 74 1.8.
that hose lying there definitely compromises cooling intake air flow.
and i live in a hot country.
here is the VW 411/412 variant set up.
what post 73 914s had was a special adaptor for the fan that went from single rectangle to single circular. to do the twin hose set up on a 914 you used all these VW parts.
i believe there was a circular clamp used to hold those up above the fan casting and it bolted to one of the fan casting bolts.
GregAmy
post Dec 6 2023, 07:22 AM
QUOTE(DC_neun_vierzehn @ Dec 6 2023, 07:36 AM) *
Thanks. I’ll feel around back there for the mounting bosses. I assume I will not have to drop the motor to install the screen?
Nope. You can reach right down there to install it easily. "Mom's Service Cover" makes it even easier. (IMG:style_emoticons/default/smile.gif)
QUOTE(wonkipop @ Dec 6 2023, 03:31 AM) *
I can't offer any info to confirm or deny, but it seems logical that it was available or was intended to be an option. Why else would VW/Porsche spend the money to develop a design/fab (and install) a right side heater box for all cars and then pay Karmann to install longs tubes on everything? The only difference on these cars is one plastic y-tube and one fabric/wire hose, easily installed during assembly.
Further, the number of cars that we find with that installed just seems that it was very easy to get.
Has anyone tried to correlate its existence to a car with a particular package? Like, for example, whether someone has the center console (mine came with both)? Or maybe it was a geographical dealer option like the A/C? - GA
wonkipop
post Dec 6 2023, 02:49 PM
QUOTE(GregAmy @ Dec 6 2023, 07:22 AM) *
as per my comments to the original poster.
in the later cars with the single hose electric blower it is not as if the normal heater, working off the cooling fan bleed flaps isn't operating or is made redundant.
its all there and its all working, down the left and right hand sides.
but as noted entirely "working" in that wonderful VW way dependent on engine revs.
the electric fan is a boost at full extension of the heater lever.
early cars have equal boost either side and i believe its delivered to that central vent that was on early 4 dashboards.
later cars have biased boost delivered through the left hand side and if the dash vent controls are set in the correct position will deliver this as a strong de mist flow to the driver side of windscreen.
so its not really like somehow the right hand side heat exchangers and long tubes have been made redundant in later cars.
of course there is nothing wrong with updating later cars to a twin hose set up.
but i think the origins of the set up, which you now see on some later cars has been lost in the midst of time since its all 50 years ago. i think that twin hose set up you see with the splitter was smart or knowledgable dealers working out which VW part you could use to create the set up. all you needed was the 412 variant twin hose splitter which fits on the later 914 fan (since the fan itself is a variant part number fan) and the long hose that was also used on the variant. and some kind of clamp to hold the hose away from blocking the air flow to the cooling fan. the issue of blocking cooling air flow was not there in the VW sedans. that fan had a ducting boot to it unlike 914s.
DC_neun_vierzehn   Show me your heater blower Y splitter set up   Dec 4 2023, 04:10 PM
NARP74   That hose sucks, way too floppy. They had a brack...   Dec 4 2023, 04:26 PM
Geezer914   Mine had a metal strap holding the hose. I ordere...   Dec 4 2023, 04:30 PM
FlacaProductions   I don't have a picture handy but i used large ...   Dec 4 2023, 04:44 PM
76-914   It’s difficult to see the wide black plastic Zip...   Dec 4 2023, 06:40 PM
porscheteck914   It’s difficult to see the wide black plastic Zi...   Dec 4 2023, 07:32 PM
jhynesrockmtn   You are on the right track being concerned. My bu...   Dec 5 2023, 08:29 AM
GregAmy   I zip-tied mine to the fan housing, and added one ...   Dec 5 2023, 08:44 AM
DC_neun_vierzehn   I zip-tied mine to the fan housing, and added one...   Dec 5 2023, 01:19 PM
GregAmy   How did you mount the screen to the shroud? Three...   Dec 5 2023, 03:28 PM
DC_neun_vierzehn   How did you mount the screen to the shroud? Thre...   Dec 6 2023, 06:36 AM
dr914@autoatlanta.com   cut to just make it to the right j pipe route ove...   Dec 5 2023, 10:16 AM
NARP74   I believe the hose with the zip ties is also less ...   Dec 5 2023, 11:02 AM
Olympic 914   Unfortunately you already purchased the Y fitting ...   Dec 5 2023, 11:52 AM
Jamie   Unfortunately you already purchased the Y fitting...   Dec 5 2023, 02:10 PM
CCE   As it came, passengers side blocked.   Dec 5 2023, 03:49 PM
brant   Took my Y off Really didn’t like blocking the co...   Dec 5 2023, 04:41 PM
Dave_Darling   I ran the long hose around the hose from the breat...   Dec 5 2023, 04:45 PM
emerygt350   I asked about this when I got my 2.0 and I followe...   Dec 5 2023, 07:29 PM
wonkipop   i think there is some kind of idea out there that ...   Dec 6 2023, 02:31 AM
GregAmy   Thanks. I’ll feel around back there for the mou...   Dec 6 2023, 07:22 AM
wonkipop   [quote name='DC_neun_vierzehn' post='3116349' dat...   Dec 6 2023, 02:49 PM
87m491   I hear you. But as someone just rehabbing a non w...   Dec 6 2023, 08:19 AM
wonkipop   I hear you. But as someone just rehabbing a non ...   Dec 6 2023, 02:27 PM
DC_neun_vierzehn   Thanks everyone for the info a pics. I am aware ...   Dec 6 2023, 06:53 AM
scott_in_nh   I 3D printed adapters so I could use the larger di...   Dec 6 2023, 07:49 AM
Dave_Darling   70-72 cars had the centrally-mounted fan with outl...   Dec 6 2023, 03:55 PM
wonkipop   70-72 cars had the centrally-mounted fan with out...   Dec 6 2023, 10:18 PM
87m491   I have this seeming factory Y pipe. http://www.914...   Dec 11 2023, 07:12 AM
wonkipop   I have this seeming factory Y pipe. [img]http://w...   Dec 11 2023, 03:13 PM
rhodyguy   I deleted the aux fan and capped the jtubes. Kind ...   Dec 11 2023, 03:50 PM
wonkipop   I deleted the aux fan and capped the jtubes. Kind...   Dec 11 2023, 03:58 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:52 PM
