> Show me your heater blower Y splitter set up
DC_neun_vierzehn
post Dec 4 2023, 04:10 PM
I bought AA's heater blower update kit with the Y splitter and installed it over the weekend. The hose that goes over to the passenger side is very long. I'm interested ins seeing how others have that hose secured as it goes over the engine from the motor to the passenger side.
I'm guessing zip ties are used? My fear is that having it loose and flopping around in the engine bay, it could get sucked into the cooling fan (and it just looks bad).
If you have this set up, please kindly share a pic of how you ran that hose from the motor to the passenger side?
TYIA
Dave_Darling
post Dec 6 2023, 03:55 PM
914 Idiot
70-72 cars had the centrally-mounted fan with outlets on the left and right of the housing, just like the 411 did.
73-74 cars had the single-outlet fan off on the left side of the engine bay, with only a single hose connecting to the driver's side heat exchanger.
75-76 cars had the same fan, but had a splitter attached to the outlet of the fan, and had one hose going to each side.
--DD
wonkipop
post Dec 6 2023, 10:18 PM
QUOTE(Dave_Darling @ Dec 6 2023, 03:55 PM) *
--DD
documented quite a lot of 75 1.8s for the L jet research.
a lot of what appear to be still very original cars.
all running the single hose fan as per 73/74.
about as many pop up with the twin hose set up as they do for 73/74s these days in well documented sales info. makes me tend to think its a later mod.
i recall old sales ads in VW magazines from the 80s the kit was around then to do the twin hose set up. a lot of cars are likely to have been modified during that time?
however its entirely possible that porsche or VW in 75 thought of a way to use up stock of 412 parts left over when 412 ceased production in 74. it could have been a dealer thing to install. def it would appear to me that the 75 L jets at least had the single hose fan as standard from factory. got a lot of examples on file.
can't speak for 2.0 L cars. were not researching and documenting.
its also a very tight squeeze to get it in under the charcoal can on the 75s.
i have noticed that the cars that have the two hose set up appear to have flipped cans where the owner or installer has mounted the can upwards of the battery tray rather than downwards.
DC_neun_vierzehn   Show me your heater blower Y splitter set up   Dec 4 2023, 04:10 PM
NARP74   That hose sucks, way too floppy. They had a brack...   Dec 4 2023, 04:26 PM
Geezer914   Mine had a metal strap holding the hose. I ordere...   Dec 4 2023, 04:30 PM
FlacaProductions   I don't have a picture handy but i used large ...   Dec 4 2023, 04:44 PM
76-914   It’s difficult to see the wide black plastic Zip...   Dec 4 2023, 06:40 PM
porscheteck914   It’s difficult to see the wide black plastic Zi...   Dec 4 2023, 07:32 PM
jhynesrockmtn   You are on the right track being concerned. My bu...   Dec 5 2023, 08:29 AM
GregAmy   I zip-tied mine to the fan housing, and added one ...   Dec 5 2023, 08:44 AM
DC_neun_vierzehn   I zip-tied mine to the fan housing, and added one...   Dec 5 2023, 01:19 PM
GregAmy   How did you mount the screen to the shroud? Three...   Dec 5 2023, 03:28 PM
DC_neun_vierzehn   How did you mount the screen to the shroud? Thre...   Dec 6 2023, 06:36 AM
dr914@autoatlanta.com   cut to just make it to the right j pipe route ove...   Dec 5 2023, 10:16 AM
NARP74   I believe the hose with the zip ties is also less ...   Dec 5 2023, 11:02 AM
Olympic 914   Unfortunately you already purchased the Y fitting ...   Dec 5 2023, 11:52 AM
Jamie   Unfortunately you already purchased the Y fitting...   Dec 5 2023, 02:10 PM
CCE   As it came, passengers side blocked.   Dec 5 2023, 03:49 PM
brant   Took my Y off Really didn’t like blocking the co...   Dec 5 2023, 04:41 PM
Dave_Darling   I ran the long hose around the hose from the breat...   Dec 5 2023, 04:45 PM
emerygt350   I asked about this when I got my 2.0 and I followe...   Dec 5 2023, 07:29 PM
wonkipop   i think there is some kind of idea out there that ...   Dec 6 2023, 02:31 AM
GregAmy   Thanks. I’ll feel around back there for the mou...   Dec 6 2023, 07:22 AM
wonkipop   [quote name='DC_neun_vierzehn' post='3116349' dat...   Dec 6 2023, 02:49 PM
87m491   I hear you. But as someone just rehabbing a non w...   Dec 6 2023, 08:19 AM
wonkipop   I hear you. But as someone just rehabbing a non ...   Dec 6 2023, 02:27 PM
DC_neun_vierzehn   Thanks everyone for the info a pics. I am aware ...   Dec 6 2023, 06:53 AM
scott_in_nh   I 3D printed adapters so I could use the larger di...   Dec 6 2023, 07:49 AM
Dave_Darling   70-72 cars had the centrally-mounted fan with outl...   Dec 6 2023, 03:55 PM
wonkipop   70-72 cars had the centrally-mounted fan with out...   Dec 6 2023, 10:18 PM
87m491   I have this seeming factory Y pipe. http://www.914...   Dec 11 2023, 07:12 AM
wonkipop   I have this seeming factory Y pipe. [img]http://w...   Dec 11 2023, 03:13 PM
rhodyguy   I deleted the aux fan and capped the jtubes. Kind ...   Dec 11 2023, 03:50 PM
wonkipop   I deleted the aux fan and capped the jtubes. Kind...   Dec 11 2023, 03:58 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:56 PM
