technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
I've got the beginnings of a performance T4.
I bought a decent 73 2.0 core complete from 914Sixer. I got a set of 1.8 SSI aftermarket heat exchangers from another member that are also pretty nice. What I am missing is the bottom tins that go between the heat exchangers and the engine case. Anytime folks put dedicated headers on a T4 these are left off... How important are they? I'm thinking "not much" but I would like insight from others. Thanks Rick |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,820 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
I've got the beginnings of a performance T4. I bought a decent 73 2.0 core complete from 914Sixer. I got a set of 1.8 SSI aftermarket heat exchangers from another member that are also pretty nice. What I am missing is the bottom tins that go between the heat exchangers and the engine case. Anytime folks put dedicated headers on a T4 these are left off... How important are they? I'm thinking "not much" but I would like insight from others. Thanks Rick i don't run them on mine - have not had them for 35 years at least. went missing when SS heat exchangers went on back in 80s. they are there to "try" and direct the exhausted cooling air out the back of car. stop it pooling under car (and in particular the area where the fuel pump is). instead with the guides it pools under the trunk and around the gearbox. this only happens when the car is sitting still in traffic idling. the rest of the time that air gets pulled out when the car is on the move, guides or no guides. they save the speedo and clutch cables from frying. i have mine wrapped in a foil insulation. as far as i am concerned with the guides you are just frying the same cables further back along their length. the important tins are the ones higher up and curved around the cylinder fins like splitters. the 914 has an inbuilt problem. called mid engined. standard VWs don't. the lower guides do something on a VW because that exhausted cooling air gets squirted straight out the back of the car. so long as you have good sealing around the engine bay tin apron the lower guides are not in my opinion necessary. others will say they are. |
Lo-Fi Version | Time is now: 15th July 2025 - 04:24 AM |
