Gasket piece inside motor, Oil filler gasket in motor |
Elkayeff |
Dec 17 2023, 10:47 PM
Newbie Group: Members Posts: 3 Joined: 17-February 23 From: Gloucester, Massachusetts Member No.: 27,168 Region Association: None |
[size=Yesterday I was replacing the pcv valve in the oil filler breather box and a piece of the cork gasket fell into the reserve chamber and while picking it out I dropped it and it went under the box through an open passage under the box. I tried to vacuum it out but no luck. I also drained the oil and ran a wire along the bottom of the inside of the motor to see if it was laying on the bottom surface. No luck there. Does anyone know if the motor will just flip it the bottom of the motor or grind it up? If it does grind it up will.it just end up in the next oil change? I hope this has not happened to others but if it has please share your solution.
Thanks |
930cabman |
Dec 18 2023, 02:33 PM
Advanced Member Group: Members Posts: 3,147 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
being a small piece, I would leave it and dispense with any flushing, etc. It will not get past the strainer and will just live there until the case is opened up. One less thing to be concerned with |
majkos1 |
Dec 18 2023, 04:04 PM
Member Group: Members Posts: 218 Joined: 11-August 17 From: Mile High 914 Member No.: 21,338 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/welcome.png) being a small piece, I would leave it and dispense with any flushing, etc. It will not get past the strainer and will just live there until the case is opened up. One less thing to be concerned with (IMG:style_emoticons/default/agree.gif) no worries, just sits somewhere after awhile, won't go through oil strainer. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:55 PM |
