Gasket piece inside motor, Oil filler gasket in motor |
Elkayeff |
Dec 17 2023, 10:47 PM
Newbie Group: Members Posts: 3 Joined: 17-February 23 From: Gloucester, Massachusetts Member No.: 27,168 Region Association: None |
[size=Yesterday I was replacing the pcv valve in the oil filler breather box and a piece of the cork gasket fell into the reserve chamber and while picking it out I dropped it and it went under the box through an open passage under the box. I tried to vacuum it out but no luck. I also drained the oil and ran a wire along the bottom of the inside of the motor to see if it was laying on the bottom surface. No luck there. Does anyone know if the motor will just flip it the bottom of the motor or grind it up? If it does grind it up will.it just end up in the next oil change? I hope this has not happened to others but if it has please share your solution.
Thanks |
Elkayeff |
Dec 19 2023, 07:20 PM
Flipped starter for a second then put 5qts through it with the taco plate port open and it came out in one piece! Made my day knowing it was out of the motor.
Lo-Fi Version | Time is now: 9th June 2024 - 08:50 PM |
