Tranz oil fill., Things you need to try. |
malcolm2 |
Dec 22 2023, 05:53 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
technicalninja |
Dec 22 2023, 11:20 AM
Senior Member Group: Members Posts: 1,343 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
The air pressure fluid installation can work PERFECTLY.
Not a single drop lost! It can ALSO make the largest mess you've ever seen done wrong. Just 10 psi makes a pool 3 feet across that will take 5lbs of cat litter to soak up. So, yes NARP74, you can make all the mess you want! Took me a couple of "pools" before I got it right... I'm now using this method even when a tranny fill tube is present. The garden sprayer seems to work slowly but it's so much better than using a manual pump! Important note: I marked the housing of the sprayer where the pick-up tube sits, and I'll lean the container to put this as the low spot. Done right you will leave less than 1 oz of fluid in the sprayer. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:39 AM |
