| TINKERGINEERING |
Dec 26 2023, 11:04 PM
Member ![]() ![]() Group: Members Posts: 228 Joined: 15-March 20 From: Sierra Madre, CA Member No.: 24,031 Region Association: Southern California
Hi. Frances and Dan from Tinkergineering here. Do these [see photo] end mounting brackets need to get pressed out, and if so how do I do that? should I need to heat it up? We got the front and rear suspension all removed. I know Ian had talked about the turbo tie rods. Why is this upgrade important/wanted?
keep on tinkering! Attached image(s)
TINKERGINEERING Front suspension control arm end bracket removal question for you all here.. Dec 26 2023, 11:04 PM
technicalninja Turbo tie rod ends- better feel, stronger design (... Dec 26 2023, 11:13 PM
technicalninja So, i went and looked in the classic forum to see ... Dec 26 2023, 11:42 PM
Superhawk996 Spend some time on Elephant Racing webpage and wat... Dec 27 2023, 02:12 AM
Chris914n6 Bushings are a good example of 'if it ain... Dec 27 2023, 02:52 AM
barefoot
Bushings are a good example of 'if it ain... Dec 27 2023, 08:24 AM
Bushings are a good example of 'if it ain... Dec 27 2023, 09:45 AM
mepstein Easiest way to remove the bushings is to heat with... Dec 27 2023, 06:50 AM
jhynesrockmtn Search through Ian's videos. Yes, those piece... Dec 27 2023, 09:23 AM
technicalninja I'm with mepstein! :agree: :agree:
On... Dec 27 2023, 10:56 AM
Dave_Darling As for the "why" the turbo tie-rod upgra... Dec 27 2023, 12:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th December 2025 - 03:34 PM |
