| TINKERGINEERING |
Dec 26 2023, 11:04 PM
Member ![]() ![]() Group: Members Posts: 228 Joined: 15-March 20 From: Sierra Madre, CA Member No.: 24,031 Region Association: Southern California
Hi. Frances and Dan from Tinkergineering here. Do these [see photo] end mounting brackets need to get pressed out, and if so how do I do that? should I need to heat it up? We got the front and rear suspension all removed. I know Ian had talked about the turbo tie rods. Why is this upgrade important/wanted?
keep on tinkering! Attached image(s)
| Chris914n6 |
Dec 27 2023, 02:52 AM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,510 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Bushings are a good example of 'if it ain't broke..." They are not easy and a press is recommended. I'd leave them be and just clean up the metal.
Turbo tie rods are not that much better or I should say the stock rods are not bad. The inner bushing gets worn so if it's sloppy do the change over. Check for slop in the rack too. Also the rubber coupler between the rack and the steering shaft. |
TINKERGINEERING Front suspension control arm end bracket removal question for you all here.. Dec 26 2023, 11:04 PM
technicalninja Turbo tie rod ends- better feel, stronger design (... Dec 26 2023, 11:13 PM
technicalninja So, i went and looked in the classic forum to see ... Dec 26 2023, 11:42 PM
Superhawk996 Spend some time on Elephant Racing webpage and wat... Dec 27 2023, 02:12 AM
barefoot
Bushings are a good example of 'if it ain... Dec 27 2023, 08:24 AM
Bushings are a good example of 'if it ain... Dec 27 2023, 09:45 AM
mepstein Easiest way to remove the bushings is to heat with... Dec 27 2023, 06:50 AM
jhynesrockmtn Search through Ian's videos. Yes, those piece... Dec 27 2023, 09:23 AM
technicalninja I'm with mepstein! :agree: :agree:
On... Dec 27 2023, 10:56 AM
Dave_Darling As for the "why" the turbo tie-rod upgra... Dec 27 2023, 12:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th December 2025 - 03:33 PM |
