| TINKERGINEERING |
Dec 26 2023, 11:04 PM
Member ![]() ![]() Group: Members Posts: 228 Joined: 15-March 20 From: Sierra Madre, CA Member No.: 24,031 Region Association: Southern California
Hi. Frances and Dan from Tinkergineering here. Do these [see photo] end mounting brackets need to get pressed out, and if so how do I do that? should I need to heat it up? We got the front and rear suspension all removed. I know Ian had talked about the turbo tie rods. Why is this upgrade important/wanted?
keep on tinkering! Attached image(s)
| mepstein |
Dec 27 2023, 06:50 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,283 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Easiest way to remove the bushings is to heat with a torch (outside your garage) until they smoke a bit and then pull them apart with some channel lock pliers or similar. New turbo tie rods don’t cost much more than stock ones but they are worth the upgrade. When it’s time to reinstall the new bushings, either use some all thread (plenty of YouTube videos or have a friend with a press set them in place for you. Ian’s videos are very good for the home diy suspension refresh.
If you have a powder coating shop near you, they can blast and re-coat everything at once. Glad to see you back on this. |
TINKERGINEERING Front suspension control arm end bracket removal question for you all here.. Dec 26 2023, 11:04 PM
technicalninja Turbo tie rod ends- better feel, stronger design (... Dec 26 2023, 11:13 PM
technicalninja So, i went and looked in the classic forum to see ... Dec 26 2023, 11:42 PM
Superhawk996 Spend some time on Elephant Racing webpage and wat... Dec 27 2023, 02:12 AM
Chris914n6 Bushings are a good example of 'if it ain... Dec 27 2023, 02:52 AM
barefoot
Bushings are a good example of 'if it ain... Dec 27 2023, 08:24 AM
Bushings are a good example of 'if it ain... Dec 27 2023, 09:45 AM
jhynesrockmtn Search through Ian's videos. Yes, those piece... Dec 27 2023, 09:23 AM
technicalninja I'm with mepstein! :agree: :agree:
On... Dec 27 2023, 10:56 AM
Dave_Darling As for the "why" the turbo tie-rod upgra... Dec 27 2023, 12:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th December 2025 - 03:37 PM |
