| 930cabman |
Jan 1 2024, 11:58 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,872 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Fitting a 2.7 into a Palma Green example from Cali, engine was built by Eksten. I have gathered a couple fan shrouds, which if either is more effective for cooling the oil,
A: Or B: Also, when fitting the intake manifolds for Weber 40 IDTP it seems as there is more gap between the manifolds and the fan shroud. Is this gap sealed? Thanks |
| johnhora |
Jan 3 2024, 04:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 909 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None
Yeah it takes a little effort to get them to work. Dremel tool is good for this and you may need some fiberglass resin epoxy and fabric.
Good luck on your project.. |
| 930cabman |
Jan 4 2024, 01:02 PM
Yeah it takes a little effort to get them to work. Dremel tool is good for this and you may need some fiberglass resin epoxy and fabric. Good luck on your project.. Thanks, I was hoping to fill with PC 7 epoxy or maybe 18 gauge with rivets Or maybe just start over with 18 or 20 gauge and return the ill fitting fiberglass ones |
930cabman Fan Shroud Jan 1 2024, 11:58 AM
Retroracer Hi - I'd suggest the green one will perform mu... Jan 1 2024, 12:32 PM
burton73 The green one shown will give you better cooling. ... Jan 1 2024, 01:16 PM
Cairo94507 @Retroracer and Bob nailed it. :beer2: Jan 1 2024, 01:16 PM
mlindner Yup, top one with baffle on #6 cylinder. Jan 1 2024, 01:26 PM
930cabman Thank you Gents, I may be coming back with a few m... Jan 1 2024, 02:42 PM
brant Fan shrouds changed early /late
It could be factor... Jan 1 2024, 02:44 PM
Dion The black one looks appropriate for a six (early) ... Jan 2 2024, 09:32 AM
johnhora here you go...shroud info...original 914-6 used th... Jan 2 2024, 03:36 PM
930cabman Great assortment John, thanks for sharing. I have ... Jan 2 2024, 05:26 PM
johnhora Are the block off plates fiberglass or metal. The ... Jan 3 2024, 11:15 AM
930cabman
Are the block off plates fiberglass or metal. The... Jan 3 2024, 01:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th October 2026 - 07:43 PM |
