> Im looking for a quality shop that can do an align bore, Help
Red76
post Jan 12 2024, 04:19 PM
I have a ‘73 914;with a 2.0L engine. The car hasn’t been on the road since 1990. Since the engine was out of the car when I bought it I decided now is a perfect time to go through it. As I tore it down I found lots of easter eggs indicating the PO tried to do a top overhaul.(valve job and new pistons and cylinders).as I dug deeper it appears that something was very out of balance in the rotating mass. With all that said im sure an align bore is in order.
Does anyone know of a shop that currently does this and can you provide contact information please.
Thanks in advance.
930cabman
post Jan 13 2024, 12:34 PM
QUOTE(Red76 @ Jan 12 2024, 05:19 PM) *
Thanks in advance.
Are you sure it is in need of align bore? What signs did you encounter that would point to the lower end being out of balance?
If it were me, I would get a set of new bearings and assemble the case/bearings and good crankshaft. Assuming the crank journals are in spec or close. If once torqued down the crank spins easily, all is good. Much cheaper/easier than sending the case out.
stownsen914
post Jan 13 2024, 05:46 PM
Whichever shop you choose can first measure the case to see if it's out of spec, and then if needed, line bore.
- Lo-Fi Version Time is now: 15th April 2026 - 10:21 AM
