Like this New Style Elec Connector |
76-914 |
Feb 7 2024, 09:04 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
technicalninja |
Feb 7 2024, 11:31 AM
Senior Member Group: Members Posts: 1,297 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
That's total BS IMHO. Here's how you do it, followed by soldering & shrink tubing. https://en.wikipedia.org/wiki/Western_Union_splice (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) I've used that for decades. I was calling it the wrong name. I called it A&P or NASA style. (IMG:style_emoticons/default/av-943.gif) They just appropriated it from someone else! I've tested three splice spans (20,16,14) for both resistance and failure. No difference in resistance on a Fluke 87 and they never failed at the splice when the wire was shock tested to breakage. In 30+ years I've never had to re-do a splice done this way. For the last 8 years I have been using type 2 heat shrink with the glue lining. Once you get "good" your spice will look like you just added heat shrink to a wire. Almost no diameter change. |
ClayPerrine |
Feb 7 2024, 11:37 AM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
That's total BS IMHO. Here's how you do it, followed by soldering & shrink tubing. https://en.wikipedia.org/wiki/Western_Union_splice (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) I've used that for decades. I was calling it the wrong name. I called it A&P or NASA style. (IMG:style_emoticons/default/av-943.gif) They just appropriated it from someone else! I've tested three splice spans (20,16,14) for both resistance and failure. No difference in resistance on a Fluke 87 and they never failed at the splice when the wire was shock tested to breakage. In 30+ years I've never had to re-do a splice done this way. For the last 8 years I have been using type 2 heat shrink with the glue lining. Once you get "good" your spice will look like you just added heat shrink to a wire. Almost no diameter change. I have been doing western union splices for years. If possible, I prefer not to have a splice. But it is not always possible. This appears to be a waterproof splice that would hold up well. And that can be used without the metal crimp connector, just use a western union splice, solder , then put it in their contraption and you have a waterproof junction. I can't see heat shrink being waterproof. |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:45 AM |
