Photoshop Gurus?, Photo editing tips |
MarkV |
Jun 2 2003, 01:22 AM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
1.How do you draw arrows on a photo in Photoshop?
2. How do you combine a string of photos into one jpg? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
SirAndy |
Jun 2 2003, 11:11 AM
Resident German Group: Admin Posts: 41,682 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(MarkV @ Jun 2 2003, 12:22 AM) 1.How do you draw arrows on a photo in Photoshop? 2. How do you combine a string of photos into one jpg? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) 1. select the line drawing tool. click on the "Line Options" tab and select line width etc. and check where you want the Arrowheads (Start, End or Both) ... 2. open all the pictures you want to combine in photoshop. then create a new (empty) pic with the desired size. simply drag&drop the layers of your old pics onto the new pic. it will automattically add those to your new pic as separate layers. resize the new layers as desired. then "Save a Copy" as jpeg ... PhotoShop is a professional Tool. it can be complicated at first but mostly because of the vast functionallity. It is not your typical "let's mess with those digi-photos a bit" crappy tool. i used to work in the printing industry for years. if you want to produce something professional, it THE program to use, otherwise, it is overkill ... Andy |
Lo-Fi Version | Time is now: 12th June 2024 - 08:36 AM |
