cgnj |
Senior Member ![]() ![]() ![]() Group: Members Posts: 627 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None ![]() ![]() |
Almost ready to wake up the 2270 after dropping the motor to change oil pump & oil pressure relief circuit. How and where did you mount the dual pole sender. I am using a braided steel hose.
Thanks in advance |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,591 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
I haven't studied the oil network, but for those using an external full flow with remote oil filter, could the block-off installed instead of the stock filter mount be a good location for the VDO pressure sensor? The switch could stay in the stock location.
I could see a nice machined aluminum block off cover with a tapped port for the VDO can. No hoses, grounded, solid and accessible from underside. (IMG:style_emoticons/default/idea.gif) Could this work? (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 05:31 PM |
