> stubborn exhaust manifold gaskets
87m491
post Feb 20 2024, 06:55 AM
Finally swapping in SS heater boxes I acquired years ago and I can't budge the existing manifold gaskets. I have read and tried a few options, trying to leverage a pick under and edge and walk it out, no luck., the gasket is very tight against the engine. Trying to lever a screwdriver head against and gasket edge and the head to deform the gasket a touch except that my head's fin started to deform before the gasket! Any other tricks before I give up and just try reusing the gaskets that won't seem to come out?
Thx
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1708433712.1.jpg)
technicalninja
post Feb 25 2024, 05:11 PM
QUOTE(87m491 @ Feb 25 2024, 02:16 PM) *
QUOTE(DC_neun_vierzehn @ Feb 20 2024, 03:51 PM) *
Sounds like someone may have applied some sealant when they installed those and they baked the copper rings on real good. Or those suckers have just been on there forever. Applying some heat to the rings could help. I would try to work a pick around the entire edge of the copper rings (delicately and then more forcefully with each full rotation) before applying heat.
Indeed. I took a smallish flat head screwdriver and reformed the last 1/4 inch at a 90 degree angle and could not get under the gasket. I used a cold chisel to cut/deform the gasket, which they did, see copper colored areas in the picture, but still absolutely no opening to lever/pull against. Then tried propane always fun 12 inches from your face. Absolutely won't budge. I reinstalled the heat exchangers and will revisit next fall when I drop the engine to reseal it and can attack from a better angle.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1708892176.1.jpg)
That one is toast now!
If you run that the groove will allow a 1000+ degree leak that will eat the head casting...
That needs to be replace now IMO.
87m491   stubborn exhaust manifold gaskets   Feb 20 2024, 06:55 AM
barefoot   If they're not damaged in the sealing face, ju...   Feb 20 2024, 06:56 AM
windforfun   What is the gasket material? Can you cut them? ...   Feb 20 2024, 11:52 AM
87m491   Theoretically copper but not very malleable from m...   Feb 20 2024, 04:46 PM
TROJANMAN   When all else fails, torch it. :devil:   Feb 20 2024, 12:17 PM
Shivers   I agree, throw some flame on it.   Feb 20 2024, 12:22 PM
930cabman   It's hard for me to see, but if it's the c...   Feb 20 2024, 01:24 PM
87m491   It's hard for me to see, but if it's the ...   Feb 20 2024, 04:48 PM
GregAmy   I snag 'em with a bent pick. $10 for ...   Feb 20 2024, 05:35 PM
windforfun   I snag 'em with a bent pick. $10 for ...   Feb 20 2024, 06:05 PM
930cabman   [quote name='GregAmy' post='3129740' date='Feb 20...   Feb 20 2024, 07:08 PM
worn   [quote name='GregAmy' post='3129740' date='Feb 2...   Feb 27 2024, 08:26 PM
DC_neun_vierzehn   Sounds like someone may have applied some sealant ...   Feb 20 2024, 05:51 PM
87m491   Sounds like someone may have applied some sealant...   Feb 25 2024, 02:16 PM
Eric_Ciampa   I remember deforming one stubborn one. I might hav...   Feb 20 2024, 07:57 PM
rhodyguy   A couple of whacks on the ring with a hammer and s...   Feb 25 2024, 02:36 PM
windforfun   :agree: :agree: :agree: Cut them with a sharp ...   Feb 25 2024, 04:26 PM
technicalninja   Sounds like someone may have applied some sealan...   Feb 25 2024, 05:11 PM
930cabman   Long thin blade slotted screwdriver, a good rap...   Feb 27 2024, 02:57 PM
87m491   Deforming of single cylinder gasket on bench I co...   Feb 28 2024, 07:23 AM
930cabman   Deforming of single cylinder gasket on bench I c...   Feb 28 2024, 10:22 AM
rjames   :agree: Don't run it without replacing it...   Feb 27 2024, 08:15 PM
73-914   1/4 in Cold chisel will cut it easy   Feb 28 2024, 11:20 AM
87m491   1/4 in Cold chisel will cut it easy As with so ...   Feb 28 2024, 01:35 PM
technicalninja   I did mine in our 75 upside down. They were stuck...   Feb 28 2024, 02:36 PM
87m491   I did mine in our 75 upside down. They were stuc...   Mar 4 2024, 07:24 AM
rhodyguy   The cold steel chisel is too blunt. Consider the i...   Feb 28 2024, 03:16 PM
GregAmy   Good on you for keeping at it!   Mar 4 2024, 08:10 AM
930cabman   Glad you got it out, but I would be careful of cau...   Mar 4 2024, 09:21 AM
- Lo-Fi Version Time is now: 5th August 2026 - 03:27 AM
