Removing those Tiny Lamps in the Flasher Knob |
76-914 |
Feb 13 2024, 07:01 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If you have fat fingers like I do it is a PITA changing out those tiny bulbs. I usually end up breaking them with needle nose pliers. I needed to replace the one in my rear window defogger switch and tried this instead . Works like a charm and everybody has one.
914_teener |
Feb 16 2024, 11:14 AM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
One more place IRIC;
On the tunnel right by the heat lever....comes on when the lights are on. |
76-914 |
Feb 25 2024, 08:09 PM
One more place IRIC; On the tunnel right by the heat lever....comes on when the lights are on. And the fresh air/defrost slide controller has some lamps too. That pencil eraser comes in handy while trying to touch the ohm meter test probes on those two tiny little wire leads. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:03 PM |
