| 87m491 |
Feb 20 2024, 06:55 AM
Member ![]() ![]() Group: Members Posts: 331 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States
Finally swapping in SS heater boxes I acquired years ago and I can't budge the existing manifold gaskets. I have read and tried a few options, trying to leverage a pick under and edge and walk it out, no luck., the gasket is very tight against the engine. Trying to lever a screwdriver head against and gasket edge and the head to deform the gasket a touch except that my head's fin started to deform before the gasket! Any other tricks before I give up and just try reusing the gaskets that won't seem to come out?
Thx (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1708433712.1.jpg) |
| GregAmy |
Feb 20 2024, 05:35 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,690 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
I snag 'em with a bent pick. $10 for "the good ones" at HF.
https://www.harborfreight.com/pick-and-hook...iece-69592.html They're cheap enough I'll almost always replace the seals. I keep a handfull in my toolbox because I don't want to have to do the job again. |
| windforfun |
Feb 20 2024, 06:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,113 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
I snag 'em with a bent pick. $10 for "the good ones" at HF. https://www.harborfreight.com/pick-and-hook...iece-69592.html They're cheap enough I'll almost always replace the seals. I keep a handfull in my toolbox because I don't want to have to do the job again. This kinda reminds me of what my dentist uses. And he's board certified. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) |
| 930cabman |
Feb 20 2024, 07:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,773 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I snag 'em with a bent pick. $10 for "the good ones" at HF. https://www.harborfreight.com/pick-and-hook...iece-69592.html They're cheap enough I'll almost always replace the seals. I keep a handfull in my toolbox because I don't want to have to do the job again. This kinda reminds me of what my dentist uses. And he's board certified. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) Which board is he certified? 2x4? |
| worn |
Feb 27 2024, 08:26 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,637 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
I snag 'em with a bent pick. $10 for "the good ones" at HF. https://www.harborfreight.com/pick-and-hook...iece-69592.html They're cheap enough I'll almost always replace the seals. I keep a handfull in my toolbox because I don't want to have to do the job again. This kinda reminds me of what my dentist uses. And he's board certified. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) Which board is he certified? 2x4? Keep this in mind: to anneal and soften copper you heat till they glow a dull red and quench it in cold water. That hardens steel, but it softens copper silver or gold. You want the gasket soft enough to deform. |
87m491 stubborn exhaust manifold gaskets Feb 20 2024, 06:55 AM
barefoot If they're not damaged in the sealing face, ju... Feb 20 2024, 06:56 AM
windforfun What is the gasket material? Can you cut them?
... Feb 20 2024, 11:52 AM
87m491 Theoretically copper but not very malleable from m... Feb 20 2024, 04:46 PM
TROJANMAN When all else fails, torch it. :devil: Feb 20 2024, 12:17 PM
Shivers I agree, throw some flame on it. Feb 20 2024, 12:22 PM
930cabman It's hard for me to see, but if it's the c... Feb 20 2024, 01:24 PM
87m491
It's hard for me to see, but if it's the ... Feb 20 2024, 04:48 PM
DC_neun_vierzehn Sounds like someone may have applied some sealant ... Feb 20 2024, 05:51 PM
87m491
Sounds like someone may have applied some sealant... Feb 25 2024, 02:16 PM
Eric_Ciampa I remember deforming one stubborn one. I might hav... Feb 20 2024, 07:57 PM
rhodyguy A couple of whacks on the ring with a hammer and s... Feb 25 2024, 02:36 PM
windforfun :agree: :agree: :agree:
Cut them with a sharp ... Feb 25 2024, 04:26 PM
technicalninja
Sounds like someone may have applied some sealan... Feb 25 2024, 05:11 PM
930cabman Long thin blade slotted screwdriver, a good rap... Feb 27 2024, 02:57 PM
87m491 Deforming of single cylinder gasket on bench I co... Feb 28 2024, 07:23 AM
930cabman
Deforming of single cylinder gasket on bench I c... Feb 28 2024, 10:22 AM
rjames
:agree:
Don't run it without replacing it... Feb 27 2024, 08:15 PM
73-914 1/4 in Cold chisel will cut it easy Feb 28 2024, 11:20 AM
87m491
As with so ... Feb 28 2024, 01:35 PM
technicalninja I did mine in our 75 upside down.
They were stuck... Feb 28 2024, 02:36 PM
87m491
They were stuc... Mar 4 2024, 07:24 AM
rhodyguy The cold steel chisel is too blunt. Consider the i... Feb 28 2024, 03:16 PM
GregAmy Good on you for keeping at it! Mar 4 2024, 08:10 AM
930cabman Glad you got it out, but I would be careful of cau... Mar 4 2024, 09:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 5th August 2026 - 03:27 AM |
